ARP "incomplete" entry
Wassim Aouadi
Level 4
Level 4
I plugged an IP device into a 2960 Catalyst switch. The port is up, but there is no MAC address learned on it:
TNSWAGCS01002(config-if)#do sh mac add int fa0/16
          Mac Address Table
Vlan    Mac Address       Type        Ports
TNSWAGCS01002(config-if)#do sh int fa0/16
FastEthernet0/16 is up, line protocol is up (connected)
  Hardware is Fast Ethernet, address is 0064.40ee.f510 (bia 0064.40ee.f510)
  Description: --- STC ---
  MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
  Keepalive set (10 sec)
  Half-duplex, 10Mb/s, media type is 10/100BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input never, output 00:00:01, output hang never
  Queueing strategy: fifo
  Output queue: 0/0 (size/max)
     14432 packets input, 923648 bytes, 0 no buffer
     Received 1392 broadcasts (0 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     48956 packets output, 3586289 bytes, 0 underruns
     0 output errors, 0 collisions, 18 interface resets
interface FastEthernet0/16
description --- STC ---
switchport access vlan 1400
switchport mode access
switchport port-security
switchport port-security violation restrict
switchport port-security mac-address sticky
priority-queue out
mls qos trust cos
spanning-tree portfast
spanning-tree bpduguard enable
end
I read that it may be a L1/L2 issue. We tried with another ethernet cable. We also tried with another IP device of the same model. That did not solve the issue.
Any idea would be appreciated.
Wass
Forum Tips: 1. Paste images inline - don't attach. 2. If you find my post helpful, please give it a thumbs up or mark it as a correct solution; You never know in the future who you might help doing so..
cadet alain
what is happening if you ping any IP from this device ?
Regards.
Alain
Hi Alain,
There are no issues with this switch. One of the symptoms of the issue is that a ping from the gateway to the host fails. The ARP "incomplete" entry appears on the connected router:
Internet  10.101.13.62            -   1cdf.0f1a.4258  ARPA   GigabitEthernet0/0.1300
Internet  10.101.13.65            0   Incomplete      ARPA
Internet  10.101.13.70            -   1cdf.0f1a.4258  ARPA   GigabitEthernet0/0.1400
I did ARP debugs:
- debug arp
- debug arp table
- debug arp interface
- debug arp database
The debug output is in the file attached. Please note that:
- the IP address of the device generating the "incomplete ARP" is 10.101.13.65
- the IP address of the gateway is 10.101.13.70 (subinterface on the branch router)
