ASA 5505 outside access for clients with dynamically assigned IPs, no outside access for clients with static IPs
John N Smith
We have an ASA configured to access the internet, which works fine for clients who have an IP address assigned by DHCP, but not for clients with manually assigned IPs.
For instance, with the DHCP server configured to give IP addresses between 172.16.101.1 and 172.16.101.10, a device may get the IP address 172.16.101.1. This machine will have connectivity to the internet.
If we then configure DHCPd server range as 172.16.101.2 to 172.16.101.10 and statically assign the 172.16.101.1 IP to the client, it will not have internet access. It will, however have inside access and VPN access.
If I try to ping 8.8.8.8, the following is logged:
ASA 3  Feb 08 2013  15:51:01  8.8.8.8  xxx.xxx.xxx.100    Deny inbound icmp src    outside:8.8.8.8    dst    servers:xxx.xxx.xxx.100 (type 0, code 0)
Where 'servers' is the name of the inside interface the request is made from and 'xxx.xxx.xxx.100' is the external IP. It seems as DNAT is not working when the client IP is static assigned.
Has anybody seen this behaviour before? It has me stumped!
Thanks for your help,
John
Could it be your experiencing a NAT problem? I noticed your line:
Nat (outside) 1
Is the same IP address range as
Nat (server) 1
Since the device is no longer in the IP address range of the servers group it may be attempting to use the NAT (outside) rule so that device is defaulting to the outside interface?
That is the only thing that looks different to me...
Thanks and good luck,
Ryan
5 Replies 5
Gabriel Hill
Could you post your configuraiton? Along with a show version?
Hi Gabriel,
Here's the config:
show running-config
: Saved
ASA Version 8.2(5)
hostname hayes-fw
enable password XXXXXXXXXXXX encrypted
passwd XXXXXXXXXXXX encrypted
names
name 212.xxx.xxx.2 DUNSTABLE
interface Ethernet0/0
description Internet
switchport access vlan 105
switchport trunk allowed vlan 100,109
switchport trunk native vlan 999
switchport mode trunk
speed 100
duplex full
interface Ethernet0/1
description Failover back-to-back
switchport access vlan 254
interface Ethernet0/2
description Internal
switchport trunk allowed vlan 100-106
speed 100
duplex full
interface Ethernet0/3
description unused
switchport trunk allowed vlan 100-104
interface Ethernet0/4
description temp-inside
switchport trunk allowed vlan 60
switchport trunk native vlan 60
interface Ethernet0/5
description unused
switchport access vlan 253
shutdown
interface Ethernet0/6
description unused
shutdown
interface Ethernet0/7
description unused
switchport access vlan 100
interface Vlan60
nameif temp-inside
security-level 100
ip address 172.16.60.253 255.255.255.0
interface Vlan100
description Mgmt
nameif mgmt
security-level 100
ip address 172.16.100.253 255.255.255.0 standby 172.16.100.252
interface Vlan101
nameif servers
security-level 90
ip address 172.16.101.253 255.255.255.0 standby 172.16.101.252
interface Vlan102
description Warehouse
nameif office
security-level 80
ip address 172.16.102.253 255.255.255.0 standby 172.16.102.252
interface Vlan103
nameif warehouse-cameras
security-level 60
ip address 172.16.103.253 255.255.255.0 standby 172.16.103.252
interface Vlan104
description Office
nameif warehouse
security-level 70
ip address 172.16.104.253 255.255.255.0 standby 172.16.104.252
interface Vlan105
nameif voip
security-level 50
ip address 172.16.105.253 255.255.255.0
interface Vlan106
nameif guest
security-level 40
ip address 172.16.106.253 255.255.255.0
interface Vlan109
nameif outside
security-level 0
ip address 80.xxx.xx.100 255.255.255.248 standby 80.xxx.xx.101
interface Vlan254
description LAN Failover Interface
ftp mode passive
object-group network FELTHAM-NETWORKS
network-object 172.16.2.0 255.255.255.0
network-object 172.16.3.0 255.255.255.0
network-object 172.16.4.0 255.255.255.0
network-object host 217.xxx.xxx.155
object-group network HAYES-NETWORKS
network-object 172.16.100.0 255.255.255.0
network-object 172.16.102.0 255.255.255.0
network-object 172.16.103.0 255.255.255.0
network-object 172.16.104.0 255.255.255.0
network-object host 192.168.1.253
network-object 80.xxx.xx.96 255.255.255.248
network-object 172.16.60.0 255.255.255.0
network-object 172.16.101.0 255.255.255.0
object-group network DUNSTABLE-NETWORKS
network-object 172.16.33.0 255.255.255.0
network-object host 212.xxx.xxx.3
access-list DUNSTABLE-VPN extended permit ip object-group HAYES-NETWORKS object-group DUNSTABLE-NETWORKS
access-list FELTHAM-VPN extended permit ip object-group HAYES-NETWORKS object-group FELTHAM-NETWORKS
access-list Nat0 extended permit ip object-group HAYES-NETWORKS object-group DUNSTABLE-NETWORKS
access-list Nat0 extended permit ip object-group HAYES-NETWORKS object-group FELTHAM-NETWORKS
access-list Nat0 extended permit ip object-group HAYES-NETWORKS object-group HAYES-NETWORKS
access-list Inbound extended permit icmp any interface voip
access-list outside_nat0_outbound extended permit ip object-group HAYES-NETWORKS object-group DUNSTABLE-NETWORKS
access-list outside_nat0_outbound extended permit ip object-group HAYES-NETWORKS object-group FELTHAM-NETWORKS
access-list outside_nat0_outbound extended permit ip object-group HAYES-NETWORKS object-group HAYES-NETWORKS
access-list outside_cryptomap extended permit ip object-group HAYES-NETWORKS object-group DUNSTABLE-NETWORKS
access-list outside_cryptomap_1 extended permit ip object-group HAYES-NETWORKS object-group FELTHAM-NETWORKS
access-list office_nat0_outbound extended permit ip object-group HAYES-NETWORKS object-group DUNSTABLE-NETWORKS
access-list office_nat0_outbound extended permit ip object-group HAYES-NETWORKS object-group FELTHAM-NETWORKS
access-list office_nat0_outbound extended permit ip object-group HAYES-NETWORKS object-group HAYES-NETWORKS
pager lines 24
logging enable
logging timestamp
logging buffer-size 8192
logging buffered debugging
logging asdm informational
mtu temp-inside 1500
mtu mgmt 1500
mtu servers 1500
mtu office 1500
mtu warehouse-cameras 1500
mtu warehouse 1500
mtu voip 1500
mtu guest 1500
mtu outside 1500
ip local pool HAYES-POOL 172.16.104.25-172.16.104.50
failover
failover lan unit secondary
failover lan interface failover Vlan254
failover interface ip failover 192.168.254.9 255.255.255.252 standby 192.168.254.10
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (temp-inside) 0 access-list Nat0
nat (temp-inside) 1 172.16.60.0 255.255.255.0
nat (servers) 0 access-list Nat0
nat (servers) 1 172.16.101.0 255.255.255.0
nat (office) 0 access-list office_nat0_outbound
nat (office) 1 172.16.102.0 255.255.255.0
nat (warehouse) 0 access-list Nat0
nat (warehouse) 1 172.16.104.0 255.255.255.0
nat (outside) 0 access-list Nat0
nat (outside) 1 172.16.101.0 255.255.255.0
route outside 0.0.0.0 0.0.0.0 80.168.58.97 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
aaa authentication http console LOCAL
aaa authorization exec authentication-server
http server enable
http 172.16.33.0 255.255.255.0 warehouse
http 172.16.100.0 255.255.255.0 mgmt
http 172.16.30.0 255.255.255.0 warehouse
http 172.16.33.0 255.255.255.0 temp-inside
http 172.16.60.0 255.255.255.0 temp-inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
sysopt noproxyarp servers
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map DM-HAYES 10 set transform-set ESP-AES-128-SHA
crypto dynamic-map DM-HAYES 10 set security-association lifetime seconds 288000
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map CM-VPN 10 match address DUNSTABLE-VPN
crypto map CM-VPN 10 set pfs
crypto map CM-VPN 10 set peer 212.xxx.xxx.3
crypto map CM-VPN 10 set transform-set ESP-AES-128-SHA
crypto map CM-VPN 20 match address FELTHAM-VPN
crypto map CM-VPN 20 set pfs
crypto map CM-VPN 20 set peer 217.xxx.xxx.155
crypto map CM-VPN 20 set transform-set ESP-AES-128-SHA
crypto map CM-VPN 99 ipsec-isakmp dynamic DM-HAYES
crypto map outside_map2 10 match address outside_cryptomap_1
crypto map outside_map2 10 set pfs
crypto map outside_map2 10 set peer 217.xxx.xxx.155
crypto map outside_map2 10 set transform-set ESP-AES-128-SHA
crypto map outside_map2 20 match address outside_cryptomap
crypto map outside_map2 20 set pfs
crypto map outside_map2 20 set peer 212.xxx.xxx.3
crypto map outside_map2 20 set transform-set ESP-AES-128-SHA
crypto map outside_map2 interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption aes
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh scopy enable
ssh 172.16.60.0 255.255.255.0 temp-inside
ssh 172.16.100.0 255.255.255.0 mgmt
ssh 172.16.33.0 255.255.255.0 mgmt
ssh 172.16.33.0 255.255.255.0 warehouse
ssh timeout 60
ssh version 2
console timeout 0
management-access warehouse
dhcp-client update dns server both
dhcpd address 172.16.60.1-172.16.60.175 temp-inside
dhcpd dns 79.xxx.xxx.84 interface temp-inside
dhcpd domain hayes.com interface temp-inside
dhcpd option 66 ascii ftp://PlcmSpIp:password@172.16.33.213 interface temp-inside
dhcpd enable temp-inside
dhcpd address 172.16.101.2-172.16.101.10 servers
dhcpd dns 79.xxx.xxx.84 interface servers
dhcpd domain hayes.com interface servers
dhcpd option 66 ascii ftp://PlcmSpIp:password@172.16.33.213 interface servers
dhcpd enable servers
dhcpd address 172.16.102.1-172.16.102.175 office
dhcpd dns 79.xxx.xxx.84 interface office
dhcpd domain hayes.com interface office
dhcpd option 66 ascii ftp://PlcmSpIp:password@172.16.33.213 interface office
dhcpd enable office
dhcpd address 172.16.103.1-172.16.103.200 warehouse-cameras
dhcpd domain cameras.hayes.com interface warehouse-cameras
dhcpd enable warehouse-cameras
dhcpd address 172.16.104.1-172.16.104.175 warehouse
dhcpd dns 79.xxx.xxx.84 interface warehouse
dhcpd domain hayes.com interface warehouse
dhcpd option 66 ascii ftp://PlcmSpIp:password@172.16.33.213 interface warehouse
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ntp server 172.16.104.254 source warehouse
webvpn
group-policy HAYES-RAVPN-POLICY internal
group-policy HAYES-RAVPN-POLICY attributes
dns-server value 172.16.104.254 79.xxx.xxx.84
vpn-idle-timeout 1440
vpn-tunnel-protocol IPSec l2tp-ipsec
username admin password /f.QRufHe2ulQB/e encrypted privilege 15
tunnel-group HAYES type remote-access
tunnel-group HAYES general-attributes
address-pool HAYES-POOL
default-group-policy HAYES-RAVPN-POLICY
tunnel-group HAYES ipsec-attributes
pre-shared-key *****
tunnel-group 212.xxx.xxx.3 type ipsec-l2l
tunnel-group 212.xxx.xxx.3 ipsec-attributes
tunnel-group 217.xxx.xxx.155 type ipsec-l2l
tunnel-group 217.xxx.xxx.155 ipsec-attributes
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:af3c281446d0d8ed5036079d3f87ba86
: end
hayes-fw# show version
Cisco Adaptive Security Appliance Software Version 8.2(5)
Device Manager Version 6.4(1)
Compiled on Fri 20-May-11 16:00 by builders
System image file is "disk0:/asa825-k8.bin"
Config file at boot was "startup-config"
hayes-fw up 22 hours 38 mins
failover cluster up 22 hours 36 mins
Hardware:   ASA5505, 512 MB RAM, CPU Geode 500 MHz
Internal ATA Compact Flash, 128MB
BIOS Flash Firmware Hub @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-5505 on-board accelerator (revision 0x0)
                             Boot microcode   : CN1000-MC-BOOT-2.00
                             SSL/IKE microcode: CNLite-MC-SSLm-PLUS-2.03
                             IPSec microcode  : CNlite-MC-IPSECm-MAIN-2.05
0: Int: Internal-Data0/0    : address is 0007.7d01.b76a, irq 11
1: Ext: Ethernet0/0         : address is 0007.7d01.b762, irq 255
2: Ext: Ethernet0/1         : address is 0007.7d01.b763, irq 255
3: Ext: Ethernet0/2         : address is 0007.7d01.b764, irq 255
4: Ext: Ethernet0/3         : address is 0007.7d01.b765, irq 255
5: Ext: Ethernet0/4         : address is 0007.7d01.b766, irq 255
6: Ext: Ethernet0/5         : address is 0007.7d01.b767, irq 255
7: Ext: Ethernet0/6         : address is 0007.7d01.b768, irq 255
8: Ext: Ethernet0/7         : address is 0007.7d01.b769, irq 255
9: Int: Internal-Data0/1    : address is 0000.0003.0002, irq 255
10: Int: Not used            : irq 255
11: Int: Not used            : irq 255
Licensed features for this platform:
Maximum Physical Interfaces    : 8
VLANs                          : 20, DMZ Unrestricted
Inside Hosts                   : Unlimited
Failover                       : Active/Standby
VPN-DES                        : Enabled
VPN-3DES-AES                   : Enabled
SSL VPN Peers                  : 2
Total VPN Peers                : 25
Dual ISPs                      : Enabled
VLAN Trunk Ports               : 8
Shared License                 : Disabled
AnyConnect for Mobile          : Disabled
AnyConnect for Cisco VPN Phone : Disabled
AnyConnect Essentials          : Disabled
Advanced Endpoint Assessment   : Disabled
UC Phone Proxy Sessions        : 2
Total UC Proxy Sessions        : 2
Botnet Traffic Filter          : Disabled
This platform has an ASA 5505 Security Plus license.
Serial Number: JMX1523Z1SU
Running Activation Key: 0x1524704f 0x6c935e43 0x0410996c 0xbd802c5c 0x0216c1b3
Configuration register is 0x1
Configuration last modified by enable_15 at 16:28:27.449 UTC Fri Feb 8 2013
Thanks for taking a look,
John
Nat (outside) 1
Nat (server) 1
Ryan
Maybe you should attempt this:
leave the IP address range of 172.16.101.0
then run the command: IP dhcpd exclude-address 172.16.101.1
See if this helps your issue it should leave the IP technically in the "server" group but simply not hand out that IP address so there should not be an IP address conflict.
Thanks Ryan, removing the 'Nat (outside) 1' line seems to have fixed the problem.
John
