few miscellaneous question on switching
sarahr202
Level 5
Level 5
Hi everybody.
I came up some question on different topics related to ccnp switch's curriculum.
Etherchannel:
Cisco documents say Cisco uses proprietary hashing algorithm to compute a binary pattern that selects a  link in the bundle.
For example  below a 2961 router with a switch module " NM-16ESW" performs" XOR" operation to compute the binary value to select a link.
R1#show etherchannel load-balance
Po1 ---> Source XOR Destination IP address
1)Would you guys share the output " show etherchannel load-balance" on your platforms?( i just want to see how different platform support different algorithm besides xor)
Layer 3 etherchannel on a sw.
On router, we first create etherchannel and then assign int into port channel.
Suppose we have a layer 3 switch  and we want to put ports f1/1-2 in port channel 1.  Can i configure like this:
sw(con) int range f1/1-2
            no switchport
            channel-group 1 mode desirable.
Or we must create a  port channel just like we do on router and then assign ports to port channel?
Backbone fast:
Suppose we have a switch with three ports, f1/1.f1/2.f1/3.
f1/1 ( root port)
f1/2( blocking)
f1/3 ( designated port).
Backbone fast is enabled on our network. Suppose sw receives a inferior bpdu on its currect root port f1/1. Sw sends out RLQ on its designated port(f1/2) and Blocked port (f1/3). Suppose sw receives the rlq reply on its designated port ( f1/2).
What will sw do? Will it expire the max-age timer on its root port ( f1/1) or will sw wait for all the rlq responses then expire the max-age timer on its root port ( f1/1) ?
thanks and have a great weekend.
2 Accepted Solutions
dominic.caron
Level 5
Level 5
6500
EtherChannel Load-Balancing Configuration:
        src-dst-ip
        mpls label-ip
EtherChannel Load-Balancing Addresses Used Per-Protocol:
Non-IP: Source XOR Destination MAC address
  IPv4: Source XOR Destination IP address
  IPv6: Source XOR Destination IP address
  MPLS: Label or IP
4500
        src-dst-ip
7000
sh port-channel load-balance
System config:
  Non-IP: src-dst mac
  IP: src-dst ip rotate 0
dominic.caron
Level 5
Level 5
LABO01(config)#int range g1/40-41
LABO01(config-if-range)#no sw
LABO01(config-if-range)#channel-group 1 mode desirable
Creating a port-channel interface Port-channel 1
Group  Port-channel  Protocol    Ports
1      Po1(RD)         PAgP      Gi1/40(D)   Gi1/41(D)
dominic.caron
Level 5
Level 5
6500
        src-dst-ip
        mpls label-ip
  MPLS: Label or IP
4500
        src-dst-ip
7000
System config:
  Non-IP: src-dst mac
dominic.caron
Level 5
Level 5
dominic.caron
Level 5
Level 5
Hi Sarah,
Backbonefast will only send RLQ on non-designated port. .
Precision, RLQ query are sent on non-designated port. RLQ answer are flooded to all designated ports.
