ASA 5505, Static routing issue.
AndrewShadid
Hello all,
I have an ASA 5505 that I just recently setup. It is functioning correctly in all regards except one:
I have a static route inside 192.168.2.0 255.255.255.0 192.168.1.3 1 that allows me to ping anything in the 192.168.2.0 network but am unable to pass any IP traffic.
The inside IP address of the ASA is 192.168.1.1 and the route gateway 192.168.1.3 is simply another router with a P2P connected to 192.168.2.0
When I add the route to a workstation routing table everything works fine. It appears the ASA is blocking something.
Any thoughts?
Andrew
22 Replies 22
I'll try to lab this up at lunch and see what I can come up with....
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
Mike Williams
Level 5
Level 5
I believe you are facing an asymmetric routing issue, which the ASA doesn't support by default. The return traffic from the 192.168.2 network will not hit the firewall, so it thinks the connection is incomplete and blocks further packets from that session. This is due to stateful packet inspection. Here is an example for performing the stateful bypass:
http://www.cisco.com/en/US/docs/security/asa/asa82/configuration/guide/conns_tcpstatebypass.html
Sent from Cisco Technical Support Android App
Hi Andrew,
I guess the ASA NAT rules preceding over your routing. Can you to a packet tracer from ASA?
Ex: packet-tracer input inside tcp 192.168.1.10 80 192.168.2.20 80
Thx
MS
MBNY1ASA1# packet-tracer input inside tcp 192.168.1.10 80 192.168.2.10 80
Phase: 1
Type: CAPTURE
Subtype:
Result: ALLOW
Config:
Additional Information:
MAC Access list
Phase: 2
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
MAC Access list
Phase: 3
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   192.168.2.0     255.255.255.0   inside
Phase: 4
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group inside_access_in in interface inside
access-list inside_access_in extended permit ip any any
Phase: 5
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 6
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
  inspect http
service-policy global_policy global
Phase: 7
Type: VPN
Subtype: ipsec-tunnel-flow
Result: ALLOW
Config:
Phase: 8
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 9
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 286357, packet dispatched to next module
Result:
input-interface: inside
input-status: up
input-line-status: up
output-interface: inside
output-status: up
output-line-status: up
Action: allow
Looks like Nat (related ipsec) configs kicking in for the traffic.
Phase: 7
Type: VPN
Result: ALLOW
Config:
Can you temporarily disable NAT (and Static nat) and try to access (leaving the static route). if this is production environment, make sure you have main window.
Thx
MS
Andrew,
Mike is 100% correct in the asymmetrical routing comment. I had the same problem as you, and this is how I fixed it.
I did all of this in GNS, so I'm hoping this will resolve your issue:
access-list bypass extended permit ip 192.168.1.0 255.255.255.0 192.168.2.0 255.255.255.0
access-list bypass extended permit ip 192.168.2.0 255.255.255.0 192.168.1.0 255.255.255.0
class-map bypass
match access-list bypass
class-map default
policy-map ServicePolicy
class default
  inspect http
class bypass
  set connection advanced-options tcp-state-bypass
service-policy ServicePolicy global
HTH,
John
IIRC you also need to explicitly disable NAT when doing state bypass.
Try adding John's config and the following NAT line:
nat (inside,inside) source static NETWORK_OBJ_192.168.1.0_24 NETWORK_OBJ_192.168.1.0_24 destination static mbny2 mbny2
You may have to apply this to the inside interface instead of global:
class-map bypass
policy-map inside_policy
  class bypass
service-policy inside_policy interface inside
Additionally, a simpler solution would be to setup the router at 1.3 as the default gateway, then you won't have to worry about asymmetric routing for your internal network. All traffic through the ASA at that point would return through the ASA.
Mike
jawad-mukhtar
Level 4
Level 4
Something is confusing
What IP are you using for P2P Router A(IP WAN) and other RouterB(IP WAN)> 2600 series Router
Jawad
