ASA 5510 Not able to route traffic between 2 LAN interfaces
igorsurev
Hi everybody,
I need help to enable traffic between two physical ports on my Cisco ASA 5510. I created access rules and NAT but traffic doe not go from accounting interface to Inside. I am able to access internet from both interfaces. Can someone pin point me in the right direction since I am not an expert in Cisco but has to finish this by the end of the week.
Thank you,
Sigor
Here is my configuration:
ASA Version 8.2(2)
hostname Cisco
domain-name xxx.com
names
interface Ethernet0/0
 description Outside
 nameif Outside
 security-level 0
 ip address 101.101.101.101 255.255.240.0
interface Ethernet0/1
 description Inside Network
 nameif Inside
 security-level 90
 ip address 192.168.10.1 255.255.255.0
interface Ethernet0/2
 description Accounting
 nameif Accounting
 security-level 100
 ip address 20.0.1.1 255.255.255.0
interface Ethernet0/3
 shutdown
 no nameif
 no security-level
 no ip address
interface Management0/0
 nameif management
 security-level 100
 management-only
ftp mode passive
clock timezone EST -5
dns domain-lookup Outside
dns server-group DefaultDNS
 name-server 8.8.8.8
 domain-name xxx.com
same-security-traffic permit inter-interface
object-group service Port-10000 tcp
 port-object eq 10000
object-group service Port-8080 tcp
 port-object eq 8080
object-group service Port-8011 tcp
 port-object eq 8011
object-group service DM_INLINE_TCP_1 tcp
 group-object Port-8080
 port-object eq www
 group-object Port-8011
object-group service DM_INLINE_TCP_2 tcp
 group-object Port-10000
 port-object eq https
 port-object eq www
object-group service rdp tcp
 port-object eq 3389
object-group service DM_INLINE_TCP_3 tcp
 group-object rdp
 port-object eq ftp
object-group service DM_INLINE_TCP_4 tcp
 port-object eq www
 port-object eq ssh
object-group service DM_INLINE_TCP_5 tcp
 port-object eq www
object-group service DM_INLINE_TCP_6 tcp
 port-object eq www
object-group service DM_INLINE_TCP_7 tcp
 group-object rdp
 port-object eq ftp
access-list Outside_access_in extended permit tcp any host 101.101.101.104 object-group DM_INLINE_TCP_5
access-list Outside_access_in extended permit tcp any host 101.101.101.102 object-group DM_INLINE_TCP_6
access-list Outside_access_in extended permit tcp any host 101.101.101.103 object-group DM_INLINE_TCP_7
access-list Outside_access_in extended permit tcp any host 101.101.101.106 eq smtp
access-list Outside_1_cryptomap extended permit ip 192.168.10.0 255.255.255.0 192.168.50.0 255.255.255.0
access-list Inside_nat0_outbound extended permit ip 192.168.10.0 255.255.255.0 192.168.50.0 255.255.255.0
access-list Inside_nat0_outbound extended permit ip 192.168.10.0 255.255.255.0 192.168.80.0 255.255.255.0
access-list CiscoIPsec_splitTunnelAcl standard permit 192.168.10.0 255.255.255.0
access-list Accounting extended permit ip 20.0.1.0 255.255.255.0 192.168.10.0 255.255.255.0
access-list Accounting extended permit ip 20.0.1.0 255.255.255.0 any
pager lines 24
logging asdm informational
mtu Outside 1500
mtu Inside 1500
mtu Accounting 1500
mtu management 1500
ip local pool IPSecDHCP 192.168.80.100-192.168.80.200 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (Outside) 1 interface
nat (Inside) 0 access-list Inside_nat0_outbound
nat (Inside) 1 0.0.0.0 0.0.0.0
nat (Accounting) 1 0.0.0.0 0.0.0.0
static (Inside,Outside) tcp 101.101.101.104 www 192.168.10.14 www netmask 255.255.255.255
static (Inside,Outside) tcp 101.101.101.104 8011 192.168.10.14 8011 netmask 255.255.255.255
static (Inside,Outside) tcp 101.101.101.104 8080 192.168.10.14 8080 netmask 255.255.255.255
static (Inside,Outside) tcp 101.101.101.102 10000 192.168.10.3 10000 netmask 255.255.255.255
static (Inside,Outside) tcp 101.101.101.102 https 192.168.10.3 https netmask 255.255.255.255
static (Inside,Outside) tcp 101.101.101.102 www 192.168.10.3 www netmask 255.255.255.255
static (Inside,Outside) tcp 101.101.101.103 ftp 192.168.10.17 ftp netmask 255.255.255.255
static (Inside,Outside) tcp 101.101.101.103 3389 192.168.10.32 3389 netmask 255.255.255.255
static (Inside,Outside) tcp 101.101.101.106 smtp 192.168.10.23 smtp netmask 255.255.255.255
static (Inside,Accounting) 192.168.10.0 192.168.10.0 netmask 255.255.255.0
access-group Outside_access_in in interface Outside
access-group Accounting in interface Accounting
route Outside 0.0.0.0 0.0.0.0 101.101.101.101 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 management
http 192.168.10.0 255.255.255.0 Inside
http 20.0.1.0 255.255.255.0 Accounting
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 32608000
crypto ipsec security-association replay disable
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs group1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256
-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set security-association lifetime kilobytes 4608000
crypto map Outside_map 1 match address Outside_1_cryptomap
crypto map Outside_map 1 set pfs group1
crypto map Outside_map 1 set peer 89.216.17.35
crypto map Outside_map 1 set transform-set ESP-3DES-SHA
crypto map Outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map Outside_map interface Outside
crypto isakmp enable Outside
crypto isakmp policy 10
 authentication pre-share
 encryption 3des
 hash sha
 group 2
 lifetime 86400
telnet timeout 5
ssh 192.168.10.0 255.255.255.0 Inside
ssh timeout 5
console timeout 0
dhcpd address 20.0.1.100-20.0.1.200 Accounting
dhcpd dns 192.168.10.19 8.8.8.8 interface Accounting
dhcpd lease 306800 interface Accounting
dhcpd domain abtscs.com interface Accounting
dhcpd enable Accounting
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
group-policy CiscoIPsec internal
group-policy CiscoIPsec attributes
 dns-server value 192.168.10.30 192.168.10.19
 vpn-tunnel-protocol IPSec
 split-tunnel-policy tunnelspecified
 split-tunnel-network-list value CiscoIPsec_splitTunnelAcl
 default-domain value xxx.com
 vpn-group-policy CiscoIPsec
tunnel-group 198.226.20.35 type ipsec-l2l
tunnel-group 198.226.20.35 ipsec-attributes
 pre-shared-key *****
tunnel-group CiscoIPsec type remote-access
tunnel-group CiscoIPsec general-attributes
 address-pool IPSecDHCP
 default-group-policy CiscoIPsec
tunnel-group CiscoIPsec ipsec-attributes
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
Cryptochecksum:2a7c97a7a22397908ef83ca6f0065919
: end
John Blakley
Without diving too deep into your config, I noticed a couple of things:
 nameif Inside
 security-level 90
 nameif Accounting
 security-level 100
On an ASA, higher security level interfaces are always allowed, by default, to lower security levels, but not the other way around. So, if you want to keep this config, you would need an acl on the Inside interface to allow traffic to go from level 90 to 100:
access-list Inside permit ip any any
access-group Inside in interface Inside
The acl will permit the traffic into either interface (outside or Accounting). As long as you have your other rules set up correctly, this should resolve your issue...
HTH,
John
HTH, John *** Please rate all useful posts ***
