Can i prevent DHCP broadcast from passing throught certain port
mahmoudyf
I have 2 locations connected throught VPN link through Cisco switches 2960, each location has a lan and has a dhcp server.
can i prevent dhcp broadcst on switch port from passing to vpn link.
Thanks in Advance
19 Replies 19
Edison Ortiz
You can configure 'DHCP Snooping' and only trust the port where the local DHCP server is connected to.
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_50_se/configuration/guide/swdhcp82.html
Edison.
Ok,
but I mean that i want to block Dhcp broadcast from my lan to go to WAN link between two locations, my problem is the traffic through WAN link.
Ok,
Mohamed Sobair
Level 7
Level 7
Unfortunately , you either block broadcast on a certain level or block all the broadcast traffic on the port.
But you have an option to rate limit the DHCP requests on the untrusted ports as recommended by Cisco to reduce DHCP packet requests.
Mohamed
Thank you very much for your help,
but i want to know how to block all broadcast on the port(i want to block broadcast from leaving the port) by command.
The command is:
Switch port block broadcast
Mohamed
thank you for your reply Mohamed
That is not working for me.  Tried it as one word or two:
(config)#int Gi0/6
(config-if)#switchport block broadcast
% Invalid input detected at '^' marker.
(config-if)#switch port block broadcast
(config-if)#switchport ?
  access         Set access mode characteristics of the interface
  autostate      Include or exclude this port from vlan link up calculation
  backup         Set backup for the interface
  block          Disable forwarding of unknown uni/multi cast addresses
  host           Set port host
  mode           Set trunking mode of the interface
  nonegotiate    Device will not engage in negotiation protocol on this interface
  port-security  Security related command
  priority       Set appliance 802.1p priority
  private-vlan   Set the private VLAN configuration
  protected      Configure an interface to be a protected port
  trunk          Set trunking characteristics of the interface
  voice          Voice appliance attributes
  <cr>
(config-if)#switchport block ?
  multicast  Block unknown multicast addresses
  unicast    Block unknown unicast addresses
*Note broadcast is not an option.
wandering_997
Which type of VPN are you using now?
Site VPN through local loop not through the internet,connect 2 branches
So there's a layer 3 connection between two branches through site-to-site vpn, right?
right
If these two branches have different networks, then DHCP broadcast packets can not pass thought the VPN link, unless you have enabled broadcast forwarding.
I mean DHCP broadcast should not cross to the other side, shouldn't it?
