ASA-5520 CPU goes to 99%
Geze2498
i have two ASA-5520's working in active active mode at the Edge of the LAN both working at a throughput of 300 Mbps. the problem i faced is that the CPU goes to 99% in peak hours and roughly over 50-60% in off peak hours. the ASA's are operating independently but the problem is the same on both sides. Dispatch Unit contributes to 75-80% of that CPU usage and about 15-20% is Logger.
is it normal or is there any fix for it?
Thank you.
5 Replies 5
balaji.bandi
Can you post show version and show process
BB
Geze2498
Sure,
Both are attached.
Thank you.
Oh your code looks old 8.2, i rather invent the wheel here.. let me give you good thread it has fix for you.
https://community.cisco.com/t5/firewalls/dispatch-unit-high-cpu/td-p/1829227
https://community.cisco.com/t5/network-management/high-cpu-due-to-dispatch-unit-in-cisco-asa-5540/td-p/2630228
BB
I will look at it and will comment.
Thank you.
