ASA 5525 || SVI || INTER VLAN ROUTING || DHCP
yogesh1
Hi All,
I have multiple vlans for inside network & i need to enable inter vlan routing in between so please let me know how can we enable this on ASA 5525 so we can establish full communication b/w d/f vlan users.
Also please let me know is it possible to configure SVI at 5525.?
Also is it possible to configure multiple dhcp for inside user as we have already running one dhcp at asa for LAN user & for same kind we required this for other two vlans. How we can identify gateway for that dhcp so specific vlan user get the ip address dynamically.
Please let me know the commands for all the above query.
dhcpd address 10.85.xx.xx-10.85.xx.xx inside
dhcpd dns 10.85.xx.xx 10.85.xx.xx interface inside
dhcpd lease 28800 interface inside
dhcpd enable inside
GigabitEthernet0/1.70    VOIP                   172.16..xx.xx  255.255.255.0   CONFIG
GigabitEthernet0/1.100   inside                 10.85.xx.xx     255.255.255.0   CONFIG
GigabitEthernet0/1.110   camera                 10.85.xx.xx     255.255.255.0   CONFIG
9 Replies 9
balaji.bandi
Configure interface ACLs to allow and/or block the required traffic.
 You can create a sub-interface with security levels.
 You need to configured switch side as trunk to allow those VLAN for the user devices.
BB
Dear Balaji,
Can you please help me with below two points as how can we create acl to allow full communication b/w vlans.
Also in L3 switch we have command of enable ip route to allow inter vlan communication is it possible to do the same on ASA 5525
1>Configure interface ACLs to allow and/or block the required traffic.
2>You can create a sub-interface with security levels.
If all the sub-interfaces on the ASA are the same security level then you can apply the global command 'same-security-traffic permit inter-interface'.  This will allow the ASA to simply route between the networks of the same security level.  If you apply different security levels you will need to write ACLs permitting your traffic.  These could be as simple as 'permit ip 10.1.0.0 255.255.0.0 10.0.0.0 255.0.0.0'.
However if that is your requirement and you already have a L3 switch I would leave the routing there and only route traffic to the firewall that is going outside of your 'domain'.  The firewall won't have the same forwarding performance as the L3 switch.
Andy
Hi Andrew,
As we have already multiple sub interfaces on firewall can you please let me know how can i enable allowed vlan all in between ASA & switch .
In cisco switches we have feature switch port mode trunk allowed vlan all please let me know how we can enable this feature on firewall also.??
So all the vlan can transfer in b/w ASA & switch.
Also please let me know the command to create new vlan in ASA 5525
 ASA1#
 ASA1# sh run int
 ASA1# sh run int GigabitEthernet0/1.70
interface GigabitEthernet0/1.70
 vlan 70
 nameif VOIP
 security-level 100
 ip address 172.16.xx.xx 255.255.xx.xx
 ASA1# sh run int GigabitEthernet0/1.100
interface GigabitEthernet0/1.100
 vlan 100
 nameif inside
 security-level 100
 ip address 10.85.xx.xx 255.255.xx.xx
 ASA1#
here is example config.
Switch side
BB(config)#int fa0/0  - change the interface where your ASA connected.
BB(config-if)#switchport
BB(config-if)#switchport trunk encapsulation dot1q
BB(config-if)#switch trunk allowed vlan 70,100 - as per your example it will allow 70 and 100 VLAN here
BB(config-if)#swtichport mode trunk
BB(config-if)#no shut
ASA Side:
config t
int e0/1
no ip address
no security-level
no nameif inside
vlan 70
nameif VOIP
security-level 100
vlan 100
nameif inside
security-level 100
BB
Dear Bala JI,
Please let me know is there any command on asa 5525 to enable trunk to allow all vlans.??
what is the Code you running in ASA ? most of the code below config should work, if not what is the error you getting and post the configuration.
This config allow all the VLAN.
Int  gi 0/1
no ip address
no security-level
no nameif inside
and map sub-interface for vlan mapping as per last config.
BB
Dear Bala ji,
I am going to run below code is this work to pass all the three vlan by sub interfaces & allow the inter vlan communication.
vlan 70
nameif VOIP
security-level 100
vlan 100
nameif inside
security-level 100
 interface GigabitEthernet0/1.110
vlan 110
nameif inside
security-level 100
ip address 192.60.xx.xx 255.255.xx.xx
test and let me know, bare in mind you need to add additional vlan trunk allowed list
switch trunk allowed vlan 70,100, 110 switch side
BB
