ASA 5545 & L3 configuration help
sachinc01
Please read following configuration & Issue & please help to resolve this.(Network Structure Router to ASA to L3 Switch)
Router 3945
R1 WAN 10.84.35.202/30
R1 LAN 10.84.35.211/28 (Primary router)
ASA (5545):-10.84.35.210/28 Outside
                   10.84.35.65/26 Inside
                  Default route for 0.0.0.0 0.0.0.0 10.84.35.211
L3:- L3 VLAN on Switch
Vlan 2 10.84.32.1/23
Vlan 3 10.84.34.1/24
Vlan 4 10.84.35.1/26
VLAN 5 10.84.35.65/26
In this case from ASA i will be reach to router (35.211 & 202) & switch (10.84.35.66)
From router able to reach ASA (10.84.35.210) & Switch also able to rech 10.84.35.65
Issue:- From L3 Switch uable to reach 10.84.35.210 (ASA) & router (10.84.35.211 )also
So some can help me what configuration i wil ned to reach ASA outside interface & Router
From L3 Switch....
Sachin
50 Replies 50
Also, can you post the output of 'show ip route' from all three devices ?
Hi Sir,
Thanks for support :)
Please find attachment...
on the firewall, add:
route inside 0 0 10.84.35.65
and on the switch, remove the IP address from the Vlan 4 interface and configure the uplink port to the ASA as following:
interface GigabitEthernet1/0/10
description uplink to ASA
no switchport
ip address 10.84.35.66 255.255.255.192
Hi ,
I have try but unable to add route on Firewall
it needs to be:
route inside 0 0 10.84.35.66
My mistake, sorry.
If adding the route doesn't help, add the other config bit:
no switchport
ASA
Ip have add route inside 0 0 10.84.35.66 1
& also make changes done on ASA but not reach ASA outside interface.
Sir,I have one daut I thing routing not work on ASA
I have received attached key with ASA Didi i need to add this key or activated my product if yes please guide me.
Please guide its urgent ..
Sachin
what is the output of:
GITFirewall# show activation-key detail
Hi sir,
Please see output.
also  please see when I will try traceroute from ASA
#traceroute 10.84.35.66 source outside1 (10.84.35.213 Asa int gi0/1)
Received following log on ASA (See attch lg & lg2)
the license looks good.
I think the problem is with the 'management-only' command on your interface. Try and remove the 'management-only':
interface GigabitEthernet0/1
description "Connected to R1"
management-only
nameif OUTSIDE1
security-level 0
When the management-only command is enabled under an interface, routing out of that interface is not allowed. In this instance, the interface only accepts direct communication. Traffic cannot pass through it.
hi sir,
remove management-only but same issue..
Please see my all config .txt (SW,router ASA)& guide me to resolved on priority.
nameif OUTSIDE1
security-level 0
ip address 10.84.35.213 255.255.255.240
revert back to the original configuration, the one you had when you originally started this post.
I don't know what the configurations look right now after all the changes. Post all three, the ASA, the router, and the switch, again. I am pretty sure it will work with removing the 'management-only' command, that was the underlying issue to start out with.
Hi Sir,
Thanks for response..
Please see  all3 device config.attached Please see this.
& revert ASAP..
Rs,
Sachin
Hi sir ,
Please phocas on only ASA & switch not able to reach ASA out side interface from Switch it this will happened then we will able able to reach router....
You will understand issue quickly.
Sachin
Can any one revert to resolved this issue.
