ASA 5545 & L3 configuration help
sachinc01
Please read following configuration & Issue & please help to resolve this.(Network Structure Router to ASA to L3 Switch)
Router 3945
R1 WAN 10.84.35.202/30
R1 LAN 10.84.35.211/28 (Primary router)
ASA (5545):-10.84.35.210/28 Outside
                   10.84.35.65/26 Inside
                  Default route for 0.0.0.0 0.0.0.0 10.84.35.211
L3:- L3 VLAN on Switch
Vlan 2 10.84.32.1/23
Vlan 3 10.84.34.1/24
Vlan 4 10.84.35.1/26
VLAN 5 10.84.35.65/26
In this case from ASA i will be reach to router (35.211 & 202) & switch (10.84.35.66)
From router able to reach ASA (10.84.35.210) & Switch also able to rech 10.84.35.65
Issue:- From L3 Switch uable to reach 10.84.35.210 (ASA) & router (10.84.35.211 )also
So some can help me what configuration i wil ned to reach ASA outside interface & Router
From L3 Switch....
Sachin
50 Replies 50
HI ,
Please find ASA config & guide me.
Hi ,
Please reply waiting from your reply ...
in your initial post, you stated that the outside interface of the ASA was configured with:
However, the running config of your ASA shows that the IP address is 10.84.35.213. Also, you have a failover IP address.
interface GigabitEthernet0/1
description "Connected to R1"
management-only
nameif OUTSIDE1
security-level 0
ip address 10.84.35.213 255.255.255.240 standby 10.84.35.209. The default route on your ASA:
route OUTSIDE1 0.0.0.0 0.0.0.0 10.84.35.209 1
points to the standby address and not to the next hop on R1. Is the IP address of R1, on the interface that is connected to the ASA, 10.84.35.211/28 as originally posted ? And is there a secondary router ?
What happens if you change:
to
route OUTSIDE1 0 0 10.84.35.211
Post the running config of R1 and the config of any secondary router as well.
Hi Sir,
You are right this is not 211 it is 210 last time I have add 210 route on switch.
Its some mistake I ask 211 route but add 210 route.
Yes here is 2 router but second router not in picture it directly connected to L3 & process is up when another ASA come then it will be in picture
Please find router config..I think something is wrong on ASA  Or need to add route please guide & suggest for closed this case
Hello
just to confirm   --- L3 <>ASA<>WAN rtr
From your post and the SW config it looks like vlan 4-5 are the wrong way around.
The SW is connected to the ASA via vlan 4 on either port gig1/0/10 or 11 (10.84.35.66/26) so if this is correct then it's default should be
IP route 0.0.0.0 0.0.0.0 10.84.35.65
Can you post the ASA config to cross check that also
res
paul
Kind Regards
Paul
Tausif Gaddi
To setup layer 3 switch to ASA communication you could assign a default gateway to your SVIs and have a default route pointing to the IP of your ASAs inside interface.
Plug in your ASA into f0/1 on the switch and assign it to a vlan. 10.1.1.1 should be the IP on the ASA interface.
