ASA and Router configuration
purpletech
Currently this is our network setup
                         Sw1 Sw2 Sw3
                               | | |                                 Sw1 10.60.0.4; Sw2- 172.16.1.4; Sw3 192.168.128.4
10.60.0.1--------------Router----------------- 172.16.1.1
            192.168.128.1 | MPLS           ACLs, NAT, VPN tunnels are on the Router and Router is the Default Gateway
                    Internet Gateway
Now we are planning to install a ASA firewall and migrate the ACLS of 10.60.*.* network and 172.16.1.* network , Nat comments and VPN tunnels to the Firewall
Can the IP address of the Router remains the same as 10.60.0.1, 172.16.1.1 and could I assign the Firewall IPs as 10.60.0.3, 172.16.1.3 (or should I need to change the IPs of the Router as 10.60.0.3 , 172.16.1.3 and assign the Firewall IPs as 10.60.0.1, 172.16.1.1)
In that case the default gateway will be 10.60.0.1 (Router) or 10.60.0.3 (Firewall)
We are planning to set up the network as
                         Internet Gateway
                            Firewall
                  10.60.0.? | | 10.60.0.? and which will be the default gateway Router or Firewall?
                           Sw1 Sw2
                 10.60.0.? | | 172.16.1. ?
                           Router
          192.168.128.1    MPLS
6 Replies 6
nkarthikeyan
Level 7
Level 7
Sorry. I couldn't understand your scenario well. But if your setup is like this SW1,2,3-->ASA-->Router-->Internet. Then your gateway should be preferred to be ASA with .1. And your rouer should be in public segment or sepearte segment as ASA outside interface is connected to the router.
Please let me know what is your exact setup. How the cotnnection from switches to asa/router is going through.
Please do rate if the given information helps.
By
Karthik
Currently it is Internet Gateway---> Router --> MPLS and Sw1, Sw2,Sw3 and the Router (10.60.0.1) is the default gateway.  We are planning  for to setup as Internet Gateway --> ASA --->Sw1, Sw2 ----> Router---> MPLS and Sw3.
Will the Router be the Default Gateway still? ACLs for Sw1 and Sw2 sunets , Nat and VPN tunnels will be on the ASA
Following is the configuration on the Router interfaces now
interface GigabitEthernet0/0
description ML LAN
ip address 192.168.128.1 255.255.255.0
ip access-group ml-in in
no ip redirects
no ip proxy-arp
ip accounting output-packets
ip nat inside
ip inspect SDM_LOW out
ip virtual-reassembly in
duplex auto
speed auto
media-type rj45
no mop enabled
interface GigabitEthernet0/1
description DMZ LAN
ip address 172.16.1.1 255.255.255.0
ip access-group dmz61in in
no ip redirects
no ip proxy-arp
ip nat inside
duplex auto
speed auto
media-type rj45
no mop enabled
interface FastEthernet0/0/0
description  Internet
switchport access vlan 10
no ip address
interface FastEthernet0/0/1
description MPLS
switchport access vlan 20
no ip address
interface FastEthernet0/0/2
description IT and LAN
switchport access vlan 30
no ip address
interface Vlan1
no ip address
interface Vlan10
ip address 200.*.*.* 255.255.255.252
ip access-group Inet-In in
no ip redirects
no ip proxy-arp
ip nat outside
load-interval 30
no mop enabled
crypto map SDM_MAP_1
interface Vlan20
description  MPLS
ip address 10.100.0.62 255.255.255.252
interface Vlan30
ip address 10.60.0.1 255.255.0.0
ip nat inside
So to install the Firewall, how to configure the Router interfaces and Firewall interfaces.
Curently it is Internet ----> Router ----> Sw1(10.60.0.*),Sw2(192.168.128.*), Sw3 (172.16.1.*)
I am planning to install the ASA as Internet -----> ASA ----> Sw1(10.60.0.*), Sw3 (172.16.1.*)----> Router -----> MPLS & Switch3 (192.168.128.*)  So, how should I configure  the Router interfaces, ASA interfaces and IP routes
So you are going to place ASA in between the internet gateway and the LAN. So you LAN switches default gateway should be ASA when it goes for accessing internet or any internet link based VPN setups. So you need to remove .1 ip for SW1 and 2 from the router and configure it in ASA as a multiple context or as the subinterfaces.
By
Karthik
Please clarify me few things on this scenario.
SW1 and Sw2 will access only Internet/VPN based connections or it has something to do with the MPLS for any LAN/WAN actions. How about the Sw3 what that will do... it doesn't goes to internet for any connection... it deals only with the MPLS.
By
Karthik
