1GB port connectivity on a Cisco 4900M
chopraavshesh
Is it possible to use 1GB (SFP / Copper) on the built-in 8 x X2-10GB ports without any Network Module of 1/10GB. If so how.
-Avshesh Chopra
Leo Laohoo
Yes, you can use a TwinGig coverter to "convert" a 10 Gbps port (X2) into two SFP ports.
Refer to Table 2 and Figure 4.
Cisco Catalyst 4900M Switch
branfarm1
Level 4
Level 4
Not to take away from Leolaohoo's response, but to clarify -- you can only use the TwinGig on the 8 port 2:1 add-on module, not the built-in ports.
--Brandon
