ASA HA Primary Swap with Firepower
NETAD
Level 4
Level 4
Hello, I’m planning on replacing the primary ASA in HA and need to know the procedure when it comes to Firepower. Do I have to re-configure mgmt and re-add it to FMC since I will need to remove the SSD and installing it in the new one?  Here’s what I’m planning on doing:
1-Power of primary and break HA by disconnecting the failover link
2-Remove the SSD drive from the existing ASA
3-Install SSD in the new firewall
4-Match the IOS on the new ASA and unshut the ports
5-Configure it for failover
6-Connect the failover link and wait for config sync
and finally failover to it and test.
what I’m not clear on is the firepower piece and if I have to re-configure it.
Here's what I had to do here:
1-Match the version of the new firewall to the existing firewall
2-re-host the licenses to the new firewall and make sure it matches the existing firewall
3-Copy the anyconnect and asdm images to the new firewall
4-Configure the new firewall as secondary and configure the existing secondary firewall as primary to prevent the secondary from sync'ing its config with a blank config from the new firewall
5-Unshut the Failover links only on the new firewall
6-Failover to the secondary
7-Power off the primary and remove the ssd
8-Power off the new firewall and install the ssd from the old firewall
Next you have to re-install firepower on the new firewall
9-Copy the firepower img file to flash
10-issue sw-module module sfr recover configure image disk0:...
    and sw-module module sfr recover boot
11-Login to the firepower module with session sfr console
12-Issue the setup command to do the initial configuration
13-Use the command system-install http|FTP to install firepower
14-Remove the old firepower from FMC
15-remove the defective firewall and rack the new one
16-connect the failover link first and make sure the configuration gets pushed to it.
17-Connect the remaining cables (outside,inside,dmz,etc)
18-Add the firepower to FMC and perform the needed upgrades
19-Failover to test.
15-Add the new one
NETAD
Level 4
Level 4
Anyone here?
15-Add the new one
