ASA OUTSIDE INTERFACE NOT ABLE TO PING
amagisupport
Unable to ping from internal host to outside interface IP ,  how do i enable icmp for outside (security 0) interface on asa 5505 to ping from inside host (security level 100) ?
Ex:- Outside interface gi 0 ,nameif outside  , is set 10.0.1.169
Inside host : -192.168.5.15 not able to ping to outside interface 10.0.1.169
Julio E. Moisa
Have you tried to apply an ACL allowing ICMP?
access-list OUTSIDE-ACL extended permit icmp any any
or
access-list OUTSIDE-ACL extended permit icmp any any echo
access-list OUTSIDE-ACL extended permit icmp any any echo-reply
(inside should be similar)
access-group OUTSIDE-ACL in interface OUTSIDE.
Also you can configure
icmp permit any any INSIDE
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
yes i did it , but this configuration is not working
is there any way to allow ?
Is this mention on any cisco website this option is not supporting on asa 5506 like that , could you share the link so that i can share with internal team ?
Jon Marshall
