ASA routing issue
Colin Higgins
Level 2
Level 2
I has an ASA 5510 with a DMZ and remote access VPN confguration
The ASA is set up with EIGRP to advertise the following networks:
172.16.100.0 /24 the DMZ
172.16.101.0 /24 the VPN pool
0.0.0.0
The internal network is 10.6.1.0 /24 and a static route is configured on the core switch that points to the VPN pool (172.16.101.0) through the ASA.
A static route is also configured on the ASA that points to 10.0.0.0 /8 through the core switch.
I have noticed several things:
1. The EIGRP routes are advertised from the ASA, but the VPN pool (172.16.101.0) is NOT being advertised.
2.Even though I have allowed the 10.0.0.0 /8 network to access the VPN pool (all protocols), I am getting an access list block when I try to ping from the VPN pool to subnets outside the directly connected (10.6.1.0) network.
Because I can't do a packet trace from the VPN pool (no interface to select), I am having a tough time troubleshooting this. I'm also not sure why the 172.16.101.0 /24 (VPN pool) is not being advertised by the ASA.
Any advice would be appreciated.
dalamdiz
Do you have the rules setup on VPN to allow the remote network access to ALL internal networks? Can you upload the config, minus the passwords? Also, try adding 172.16.101.0/24 to the EIGRP table on the core. Even though you have a static route, all other devices need to know that traffic for that network has to come through the core that has the network in its EIGRP table.
I have a rule setup that allows the internal networks to access the vpn pool, and I also set up a NAT exemptio
n.
I can connect to the the vpn and ping devices on the same subnet as the internal interface, and I can use one-way communication with devices on remote networks (telnet, etc.)
I enablee reverse-route injection in hopes of advertising the VPN pool via EIGRP, but it didn't work.
The strange this is, even though I have rules set up for the internal networks to be able to ping the VPN pool (172.16.101.0/24) and the DMZ (172.16.100.0/24), and the DMZ interface, if I do a packet trace from ASDM, it immediately fails before even doing a lookup. It just presents question marks for the interface, etc. (other traces from inside and outside work fine).
Not sure what the issue is here
