ASA5515 SMTP issue failed to permit SMTP traffic please help!!
Neko-Chen
I have close inspect ESMTP via "no inspect esmtp", but still failed to access smtp service. outlook or other email software still said failed to connect to host. failed to send emails.
I have no idea what's problem. Please help me. thanks. here is configuration
ASA Version 8.6(1)2
hostname  ASA
domain-name ***
enable password K** encrypted
passwd *encrypted
names
interface GigabitEthernet0/0
 nameif outside
 security-level 0
 ip address *** 255.255.255.248
interface GigabitEthernet0/1
 nameif inside
 security-level 100
 ip address *** 255.255.254.0
interface GigabitEthernet0/2
 shutdown
 no nameif
 security-level 100
 no ip address
interface GigabitEthernet0/3
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet0/4
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet0/5
 shutdown
 no nameif
 no security-level
 no ip address
interface Management0/0
 nameif mgmt
 security-level 100
 ip address ***255.255.255.0
 management-only
boot system disk0:/asa861-2-smp-k8.bin
ftp mode passive
clock timezone peking 8
dns domain-lookup outside
dns server-group DefaultDNS
 name-server ***
 domain-name ***
same-security-traffic permit intra-interface
object network my-inside-nat
 subnet ***
object network vpnaddress
 subnet ***
object network LAN
 subnet ***
object network NETWORK_OBJ_***
 subnet ****
object network FTP_Address
 host ***
object network ftp_internal
 host ***
object network CM
 subnet ***
 description CM
object network FTP
 host ***
object network FTP_server
 host ***
object-group network DM_INLINE_NETWORK_1
 network-object ***
object-group service DM_INLINE_TCP_1 tcp
 port-object eq ftp
 port-object eq ftp-data
access-list 102 extended permit tcp any any eq smtp
access-list 102 extended permit icmp any any
access-list 102 extended permit tcp any host **** object-group DM_INLINE_TCP_1
access-list testgroup_splitTunnelAcl standard permit ***255.255.254.0
access-list outside_cryptomap_10.10 extended permit ip any any
access-list outside_cryptomap_10.10_1 extended permit ip object vpnaddress ****
access-list 00_SplitTunnelAcl standard permit ***
access-list 00A_SplitTunnelAcl standard permit ***
access-list inside_access_in extended permit ip any any
access-list Test_access_in extended permit ip any any
access-list outside_access_in extended permit icmp any any time-exceeded
access-list outside_access_in extended permit icmp any any unreachable
access-list 101 extended permit tcp any any eq smtp
pager lines 24
logging enable
logging timestamp
logging buffered informational
logging trap informational
logging asdm informational
logging host inside ****
no logging message 106015
no logging message 313001
no logging message 313008
no logging message 106023
no logging message 710003
no logging message 106100
no logging message 302015
no logging message 302014
no logging message 302013
no logging message 302018
no logging message 302017
no logging message 302016
no logging message 302021
no logging message 302020
flow-export destination inside ****
flow-export template timeout-rate 1
flow-export delay flow-create 60
mtu outside 1500
mtu inside 1500
mtu mgmt 1500
ip local pool VPNPool **** mask 255.255.255.0
ip local pool TestPool ****-**** mask 255.255.255.0
no failover
icmp unreachable rate-limit 10 burst-size 5
icmp permit ***255.255.254.0 inside
asdm image disk0:/asdm-66114.bin
no asdm history enable
arp timeout 14400
nat (inside,outside) source static any any destination static vpnaddress vpnaddress
 nat (inside,outside) dynamic interface
 nat (inside,outside) static*** service tcp ftp ftp
access-group 102 in interface outside
access-group inside_access_in in interface inside
route outside 0.0.0.0 0.0.0.0 ***1
route outside ** 255.255.255.0 ** 1
route inside *** 255.255.255.0 ** 1
route outside *** 255.255.255.0 **1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
aaa authentication telnet console LOCAL
http server enable
http ***255.255.255.255 mgmt
http *** 255.255.255.255 inside
http ****255.255.255.255 inside
http *** 255.255.254.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
virtual telnet***
crypto ipsec ikev1 transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec ikev2 ipsec-proposal DES
 protocol esp encryption des
 protocol esp integrity sha-1 md5
crypto dynamic-map cisco 10 set ikev1 transform-set ESP-DES-MD5
crypto dynamic-map cisco 10 set ikev2 ipsec-proposal DES
crypto dynamic-map cisco 10 set reverse-route
crypto map outside_map 10 ipsec-isakmp dynamic cisco
crypto map outside_map interface outside
crypto ca trustpoint ASDM_TrustPoint0
 enrollment self
 subject-name CN=***
 crl configure
crypto ca certificate chain ASDM_TrustPoint0
 certificate 7f26c050
  quit
crypto ikev2 policy 40
 encryption des
 integrity sha
 group 5 2
 prf sha
 lifetime seconds 86400
crypto ikev2 enable outside client-services port 443
crypto ikev2 remote-access trustpoint ASDM_TrustPoint0
crypto ikev1 enable outside
crypto ikev1 policy 1
 authentication pre-share*****
 encryption des
 hash sha
 group 2
 lifetime 43200
crypto ikev1 policy 10
 encryption des
 hash md5
 group 2
 lifetime 86400
crypto ikev1 policy 130
 authentication crack
 encryption des
 hash sha
 group 2
 lifetime 86400
crypto ikev1 policy 140
 authentication rsa-sig
 encryption des
 hash sha
 group 2
 lifetime 86400
telnet ** ** inside
telnet timeout 5
ssh timeout 5
console timeout 0
management-access inside
threat-detection basic-threat
threat-detection statistics
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
ssl encryption des-sha1
ssl trust-point ASDM_TrustPoint0 outside
 tunnel-group-list enable
 tunnel-group-preference group-url
group-policy testgroup internal
group-policy testgroup attributes
 dns-server value ****
 split-tunnel-policy tunnelspecified
 split-tunnel-network-list value testgroup_splitTunnelAcl
 default-domain value p1add.radd.lan
group-policy "GroupPolicy_00 0A00VPN" internal
group-policy "GroupPolicy_000 VPN" internal
group-policy "GroupPolicy_00 VPN" attributes
 wins-server none
 vpn-tunnel-protocol ***-client
 split-tunnel-network-list value ***_SplitTunnelAcl
 default-domain value ***
 address-pools value TestPool
group-policy ***internal
group-policy ***attributes
 vpn-tunnel-protocol ikev1 l2tp-ipsec
 split-tunnel-network-list value 000_SplitTunnelAcl
 address-pools value VPNPool
tunnel-group testgroup type remote-access
tunnel-group testgroup general-attributes
 address-pool VPNPool
 authorization-server-group LOCAL
tunnel-group testgroup ipsec-attributes
 ikev1 pre-shared-key *****
tunnel-group *** type remote-access
tunnel-group **** general-attributes
 default-group-policy ***
tunnel-group *** ipsec-attributes
tunnel-group "AnyConnect VPN" type remote-access
tunnel-group "AnyConnect VPN" general-attributes
tunnel-group "AnyConnect VPN" webvpn-attributes
 group-alias "AnyConnect VPN" enable
 address-pool TestPool
 default-group-policy "GroupPolicy_AnyConnect VPN"
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
policy-map global-policy
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
hpm topN enable
Cryptochecksum:d7d6c3e7ed9892285702aab47319fd95
: end
7 Replies 7
Marvin Rhoads
It looks like you have a mail server on the inside you want clients to be able to reach from the outside. You already have the access-list on the outside interface. However, you will also need a static NAT for the server so that it has a unique public address.  Otherwise incoming traffic will have no way of knowing the real ip address of the mail server.
Hi Marvin,
I have no mail server on the inside. mail server is outside, all users need   to connect to outside mail server. but it is failed when send email. failed to telnet the mail server, I have set "no inspect esmtp", but still no work.
Please run packet-tracer to highlight the flow through your ASA as follows:
packet-tracer input inside tcp <address of a client PC> 1025 <address of yor outside mail server> 25
(substituting your actual ip addresses for the bracketed variables) and share the output.
Also, you don't need:
...as a higher security interface is by default allowed to communicate with lower security interfaces.
Hi Marvin, I have deleted
then try to telnet, but still failed.
the result of packet-tracer :
ASA#packet-tracer input inside tcp 172.28.76.191 25 111.221.119.105 25
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
MAC Access list
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   0.0.0.0         0.0.0.0         outside
Phase: 3
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 4
Type: NAT
Subtype:
Result: ALLOW
Config:
Dynamic translate 172.28.76.191/25 to *.*.210.26/19
Phase: 5
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 6
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 368953, packet dispatched to next module
Result:
input-interface: inside
input-status: up
input-line-status: up
output-interface: outside
output-status: up
output-line-status: up
Action: allow
Hi Marvin, do you have any idea for my problem? I can not solve this problem... please help...thanks
According to your packet tracer output, the ASA is not blocking the traffic from a client to the mail server. Can you watch the ASA logs when you try connect and look for something unusual?
The best way is to make sure you are logging at level 6 and then try to connect. Watch the logs in ASDM (Monitoring > Logging > Real Time Log Viewer). You should see the tcp flows being setup.
You can also go on your server and watch for the incoming connection requests (note that they will be coming from the ASA outside interface - the NAT address your clients will be using)
Hi Marvin,
I found what is the problem, it was blocked by Mcafee VirusScan, no ASA's issue.
Thanks for you help.
