ASIC Drop in N7K-M132XP-12
athambi
I am looking for a command that will indicate that there are ASIC  level packet drops due to  over subscription
Parvesh Paliwal
Level 3
Level 3
can you elaborate exactly what you want ?
what I could understand is - you need the command :
show platform port-asic stats drop
It would be nice , If this command  could  show packet drops on the ASIC level on the above mentioned card  on Nexus 7018.But this  command is not  working on 7018.
Cheers
Ajai
you can use the following command
attach module X
show hardware internal statistics pktflow dropped
show hardware internal statistics pktflow rates
Hope this will help.
jkilleda
Level 3
Level 3
Hello Ajai,
You can use this command "Show hardware internal statistics pktflow dropped".
