Network monitoring software solutions ?
carl_townshend
Hi All
I'm sure this has been discussed before, what tools are people using and find most useful for Network monitoring, so things like availability, capacity, usage etc etc.
Things like Solarwinds / Whatsup Gold, SevOne etc
Cheers
5 Replies 5
Deepak Kumar
It depends on you and your requirement. I like PRTG network monitoring tool.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Full monitoring for thousands of switches and routers etc
Port level based info etc
Not sure PRTG will cut it! we already use that for snmp graphing / netflow etc
It is possible with PRTG. It also comes with ISP version
Deepak Kumar.
Deepak Kumar,
I've heard some good things about SolarWinds. I'm interested with their customizable reporting feature.
PI is going not going to last long. In the next two years I can see the slow migration to DNA-C.
SolarWinds NPM works really well.  Pricewise, It is also very reasonable to maintain the annual service contract and the support is fine too.
