Ask for help :( "%ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi1/0/17: Power given, but Power Controller does not report Power Good"
sunsteel7378
This question is used a translator....
Current conditions
 - SW1 ----- Power injector ------ AP(cisco is not another model)
 - Port, AP, Power injector, Switch <-> Injector UTP cable  Problems occur even after replacement
 - Power injector <->AP UTP canle No exchange
 - Poe was OFF the function. This is because it is being used for Power Injector. -> Do not generate failure logs
 - But even if another AP is turned ON POE function, no error messages.
SW1#show logging (5 mins cycle persists)
May  4 10:37:32.527: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi1/0/17: Power given, but Power Controller does not report Power Good
May  4 10:37:42.556: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/17, changed state to down
May  4 10:37:43.562: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/17, changed state to down
May  4 10:37:50.032: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/17, changed state to up
May  4 10:37:52.046: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/17, changed state to up
May  4 10:38:03.238: %ILPOWER-7-DETECT: Interface Gi1/0/17: Power Device detected: IEEE PD
SW1#show cable-diagnostics tdr interface gi 1/0/17    <----- Issues AP
TDR test last run on: May 04 10:49:14
Interface Speed Local pair Pair length        Remote pair Pair status
Gi1/0/17  1000M Pair A     84   +/- 10 meters Pair B      Normal
                            Pair B     84   +/- 10 meters Pair A      Normal
                            Pair C     84   +/- 10 meters Pair D      Normal
                            Pair D     84   +/- 10 meters Pair C      Normal
SW1#show cable-diagnostics tdr interface gigabitEthernet 1/0/18    <--------- Normal AP
TDR test last run on: May 04 11:01:04
Gi1/0/18  1000M Pair A     92   +/- 10 meters Pair B      Normal
                           Pair B     92   +/- 10 meters Pair A      Normal
                           Pair C     92   +/- 10 meters Pair D      Normal
                           Pair D     92   +/- 10 meters Pair C      Normal
SW1#show cable-diagnostics tdr interface gigabitEthernet 1/0/1   <--------- Normal AP
TDR test last run on: May 04 11:01:56
Gi1/0/1   1000M Pair A     79   +/- 10 meters Pair B      Normal
                           Pair B     79   +/- 10 meters Pair A      Normal
                           Pair C     79   +/- 10 meters Pair D      Normal
                           Pair D     79   +/- 10 meters Pair C      Normal
SW1#show power inline    <-------- (Check every 5 seconds)
Module   Available     Used     Remaining
               (Watts)     (Watts)    (Watts)
1              370.0      200.2       169.8
Interface Admin  Oper       Power     Device                           Class   Max
                                            (Watts)
SW1#show power inline | in 17
Gi1/0/17  auto     off        0.0                 n/a                               n/a   30.0
Gi1/0/17  auto     on         15.4             Ieee PD                         0     30.0
Gi1/0/17  auto     on         15.4             Xirrus XR2426, 1.0G     0     30.0
Gi1/0/17  auto     faulty     0.0              n/a                                 n/a   30.0
Leo Laohoo
Plug the Xirrus AP directly to the switch port and see if the logs go away or not.
