07-15-2021 01:27 AM - edited 07-15-2021 01:28 AM
Dear Community,
Kindly ask, can we stack switch different model for the interface type?
let say I have 9300-24T and 9300-24S, can I stack both of them ?
any suggestions are appreciated
thank you all
Solved! Go to Solution.
07-15-2021 06:41 AM
yes correct, make sure both need to same version of code.(that is the basic requirement).
07-15-2021 01:34 AM - edited 07-15-2021 01:37 AM
Mixed stacking between C9300X and C9300 switches are supported at StackWise-480 speed. However, you cannot stack fixed uplink switches with modular uplink switches or other Cisco Catalyst switches.
More information can be find here :
07-15-2021 01:39 AM
Hi Balaji
Thanks for your answer
I assume, it is fine if I have 9300-24T (BaseT) be stacked with 9300-24S (SFP Based) since both of the are modular uplink just use the stacking cable StackWise-480?
07-15-2021 06:41 AM
