ASR 100-X Management Interface with HSRP doesn´t work
lp-muc
we have two ASR 1001-X with IOS-XE 9.03.13. On both Management Interfaces is  HSRP configured:
Prime:
interface GigabitEthernet0
 vrf forwarding Mgmt-intf
 ip address 10.11.100.2 255.255.255.0
 no ip proxy-arp
 standby version 2
 standby 961 ip 10.11.100.1
 standby 961 priority 110
 standby 961 preempt
 standby 961 authentication md5 key-chain HSRP2
 standby 961 name 961
 standby 961 track 2 decrement 10
 speed 1000
 no negotiation auto
Secondary:
 ip address 10.11.100.3 255.255.255.0
 no ip proxy-arp
 standby version 2
 standby 961 preempt
 speed 1000
 no negotiation auto
show standby:
GigabitEthernet0 - Group 961 (version 2)
  State is Active
    5 state changes, last state change 01:16:40
  Virtual IP address is 10.11.100.1
  Active virtual MAC address is 0000.0c9f.f353 (MAC In Use)
    Local virtual MAC address is 0000.0c9f.f353 (v2 default)
  Hello time 3 sec, hold time 10 sec
    Next hello sent in 0.800 secs
  Authentication MD5, key-chain "***"
  Preemption enabled
  Active router is local
  Standby router is unknown
  Priority 110 (configured 110)
    Track object 2 state Up decrement 10
  Group name is "961" (cfgd)
I can ping both IPs (.2/.3) vice versa. No Firewall or ACL inbetween.
They can not see eachother. Both are  in active mode.
Does somebody know why this configuration doesn´t work on the ASR 1001-X ?
robert
7 Replies 7
Reza Sharifi
I have never done it and not sure if you can configure HSRP on the out-of-band management interfaces. They are supposed to be connected to an out-of-band management switch and work just like a host (no layer-2).  How are the 2 interfaces connected together?
I have done this on other Devices and it worked. They are connected over 2960 Switches Layer 2.
They can ping eachother.
Robert
Ok.  Good to know.  Both routers have priority 110.  Can you change one to default (100) and test again?
Already done. I had the secondary on 80, 85 and 100. Stayed the same.
For testing, have you tried removing the authentication?
Yes, of course.
Same problem for me! Did you manage to solve it in some way?!
Anyone experimenting this problem?
Many thanks in advance
Enrico
