ASR 1001 exact process usage command.
mmendis
Level 4
Level 4
Hi all,
We are using a ASR 1001 series router as a gateway router. What is the exact command to see the process usage of the system??
Thanks.
show processes memory
show memory
show platform software status control-processor brief
show platform software process slot R0 monitor
http://www.cisco.com/en/US/products/ps9343/products_tech_note09186a0080af252a.shtml
Inayath
********PLZ DONT FORGET TO RATE THIS POST IF THIS INFO IS HELPFULL***************************
mmendis
Level 4
Level 4
Anyone can you help
show memory
Inayath
Thanks Sharieff
