10-27-2011 08:20 AM - edited 03-07-2019 03:05 AM
Thanks in advance for your help!
what license do I need to create a IPSEC tunnel?
I have an ASR 1001, running ?
System returned to ROM by reload at 10:14:31 UTC Tue Aug 23 2011
System image file is "bootflash:asr1001-universalk9_npe.03.03.00.S.151-2.S.bin"
Last reload reason: PowerOn
License Info:
License UDI:
Device# PID SN UDI
*0 ASR1001 JAE153402YI ASR1001:JAE153402YI
License Package Information for Module:'asr1001'
Module name Image level Pri Config Valid license
asr1001 adventerprise 1 NO adventerprise
advipservices 2 NO advipservices
ipbase 3 NO ipbase
Module name Current Level Reboot Level
asr1001 ipbase ipbase
cisco ASR1001 (1RU) processor with 1202026K/6147K bytes of memory.
4 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
7782399K bytes of eUSB flash at bootflash:.
10-31-2011 06:22 AM
advipservices
10-31-2011 06:58 AM
You need to have advipservicesk9 bundle in order to configure vpn tunnels.
Please rate the helpfull posts.
Naidu.
04-09-2014 11:09 AM
Advanced IP Services an the IPsec Right to Use Licence.
