03-05-2008 07:58 PM - edited 03-05-2019 09:34 PM
I have P/Ns for Cisco 2811 router fans as follows:
ACS-2811-FAN-1/2= and ACS-2811-FAN-3=
But I do not have part numbers for fans used in 2801, 2821 and 2851 routers.
Does anyone have these prt numbers?
It doesn't make sense to change the whole router for just a fan failure.
03-11-2008 02:48 PM
I think Fan modules are not replaceble. Full chassis need to be ordered if FANs are failing.
03-11-2008 02:57 PM
Its not something most of us in here would do . It will certainly void any kind of warranty or maintenance contract on the device.
02-01-2009 09:12 PM
ACS-2821-51-FANS= should be orderable from Cisco. Why should we replace the whole chassis as the previous reply suggests
04-09-2014 09:06 AM
for the 2821 and 2851 routers the fan is the same : ACS-2821-51-FANS=
for 2801 the whole chassis needs to be replaced
