ASR 1002-F Port-Channel to 3750X
ewells1492
Hello. I'm trying to setup a Port-Channel (or EtherChannel) between my ASR 1002-f Router and 3570X Switch.
I need to pass VLANs 10,20,30 & 40 over the Port-Channel (This is why I set the Switch ports as Trunks)
Need to confirm if this is the correct approach as the documentation can sometimes be a bit unclear.
Would you be so kind as to take a look below and advise if this is the correct approach and/or if i'm all wrong.
And provide direction/advice in order to achieve my goal.
Much appreciated :)
On ASR 1000 Router:
Router# configure terminal
Router(config)# interface port-channel 1
Router(config-if)# ip address 192.168.1.1 255.255.255.0
Router(config-if)# channel-group 1 mode active
Router(config-if)# exit
Router(config)#end
Router(config)# interface gigabitethernet0/0
Router(config)#end
Router(config)# interface gigabitethernet0/1
Router(config)#end
Router# write mem
The above should create a Port-Channel, assign an IP address of 192.168.1.1 and MASK of 255.255.255.0
to the Port-Channel itself. Then add Ports GigabitEthernet0/0 & GigabitEthernet0/1 to the Port-Channel as members.
Correct ??
On the 3750X Switch:
Switch# configure terminal
Switch(config)# interface port-channel 1
Switch(config-if)# no switchport
Switch(config-if)# no ip address
Switch(config-if)# end
Switch#
Switch(config)# interface range gigabitethernet1/0/49 - 50
Switch(config-if-range)# switchport mode trunk
Switch(config-if-range)# switchport trunk encapsulation dot1Q
Switch(config-if-range)# switchport trunk native vlan 10
Switch(config-if-range)# switchport trunk allowed vlan 10,20.30.40
Switch(config-if-range)# channel-group 1 mode on
Switch(config-if-range)# exit
Switch(config)#end
Switch# write mem
The above should create a Port-Channel, Then add Ports GigabitEthernet1/0/49 & GigabitEthernet1/0/50 to the Port-Channel as members.
Then allow vlans 10,20,30 & 40 over the Port-Channel correct ??
you need sub interface at ASR Side, i believe the code should work.
example : ( apart from basic port-channel config both the side)
ASR
interface Port-channel1.10
 encapsulation dot1Q 10
Switch side
interface vlan 10
ip address 192.168.1.10 255.255.255.0
BB
balaji.bandi
you want pass the VLAN to ISR you need to have L2 trunk and sub interface configure with do1q tag.
BB
Thanks for your reply.
Do you mean sub-interfaces created on the Interfaces on the Switch (3750). Or the ASR Router. (ASR 1002-F) ?
Also just to clarify, I only have an ASR 1002-F Router. Don't have an ISR (If you are referring to an Integrated Service Router. such as a 2951)
Would the same commands to accomplish my goal work with my ASR 1002-F Router ???
ASR
Switch side
interface vlan 10
BB
Thanks so much
I will give this a try today and let you know the outcome
Thanks again
Cheers
