ā12-28-2014 12:44 AM - edited ā03-07-2019 10:01 PM
I have a asr 9000 router i want to view the taffic netflow in interfaces using Netflow Analyzer but cant see a lot of traffic evenif we apply command show we see the same result is there a IOS bug ?
Solved! Go to Solution.
ā12-28-2014 10:43 PM
Hello Ahmed,
You may want to have a look at below article. The below article has all the things which we require to check and configure the NETFLOW.
https://supportforums.cisco.com/document/113076/asr9000xr-netflow-architecture-and-overview
Below is from CCO suggesting limitations as well.
http://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k_r4-2/netflow/configuration/guide/b_netflow_cg42asr/b_netflow_cg42asr_chapter_00.html#con_1068018
HTH,
Nikhil
Hello Ahmed,
HTH,
Nikhil
ā12-30-2014 05:34 AM
Thank you for your help Nikhil
