07-14-2018 06:01 AM - edited 03-08-2019 03:40 PM
Hello all,
%SPA_OIR-6-OFFLINECARD: SPA (12xGE-2x10GE-FIXED) offline in subslot 0/0
I am getting this above error in one of the working ASR-920-12CZ-A router..
the the one gig ports are perfectly fine also the ten gig ports...its all in "no shutdown" state...Could somebody help me understanding what exactly the error is all about ?
here is the log of the router I have highlighted the event:
Calculating SHA-1 hash...done
validate_package: SHA-1 hash:
calculated 220e0548:2d9db03b:40f90222:ea7bcab9:a0cc136e
expected 220e0548:2d9db03b:40f90222:ea7bcab9:a0cc136e
invalid RP package type 1000
Warning: filesystem is not clean
Located asr920-universalk9_npe.03.18.00.sp.156-2.sp-ext.bin
Image size 331586556 inode num 32, bks cnt 80954 blk size 8*512
Boot image size = 331586556 (0x13c39bfc) bytes
Package header rev 2 structure detected
calculated b2dc9cd5:b580a621:e8747f71:636e0e99:a50920ef
expected b2dc9cd5:b580a621:e8747f71:636e0e99:a50920ef
Image validated
Passing control to the main image..
%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash 1 contained errors which were auto-corrected.
%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash 5 contained errors which were auto-corrected.
%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash 6 contained errors which were auto-corrected.
%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash 7 contained errors which were auto-corrected.
%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash 8 contained errors which were auto-corrected.
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, ASR920 Software (PPC_LINUX_IOSD-UNIVERSALK9_NPE-M), Version 15.6(2)SP, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Wed 27-Jul-16 09:11 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2016 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
Tmpdisk creation successful, status = 0
flashfs[16]: 0 files, 1 directories
flashfs[16]: 0 orphaned files, 0 orphaned directories
flashfs[16]: Total bytes: 1935360
flashfs[16]: Bytes used: 1024
flashfs[16]: Bytes available: 1934336
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco ASR-920-12CZ-A (Freescale P2020) processor (revision 1.0 GHz) with 901400K/6147K bytes of memory.
Processor board ID CAT1903U0DM
12 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
3670016K bytes of physical memory.
1328927K bytes of SD flash at bootflash:.
Press RETURN to get started!
*Jul 9 05:32:14.192: %SMART_LIC-6-AGENT_READY: Smart Agent for Licensing is initialized
*Jul 9 05:32:16.541: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = ASR-920-12CZ-A Next reboot level = advancedmetroipaccess and License = advancedmetroipaccess
*Jul 9 05:32:36.682: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlanCannot Get the number of ports in MAC notification
*Jul 9 05:32:40.104: %LINK-3-UPDOWN: Interface Lsmpi0, changed state to up
*Jul 9 05:32:40.106: %LINK-3-UPDOWN: Interface EOBC0, changed state to up
*Jul 9 05:32:40.106: %LINEPROTO-5-UPDOWN: Line protocol on Interface LI-Null0, changed state to up
*Jul 9 05:32:40.107: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to down
*Jul 9 05:32:40.127: %LINK-3-UPDOWN: Interface LIIN0, changed state to up
*Jul 9 05:32:40.873: %LINEPROTO-5-UPDOWN: Line protocol on Interface Lsmpi0, changed state to up
*Jul 9 05:32:40.873: %LINEPROTO-5-UPDOWN: Line protocol on Interface EOBC0, changed state to up
*Jul 9 05:32:40.874: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Jul 9 05:32:40.874: %LINEPROTO-5-UPDOWN: Line protocol on Interface LIIN0, changed state to up
*Jul 9 05:32:41.038: %IOSXE_MGMTVRF-6-CREATE_SUCCESS_INFO: Management vrf Mgmt-intf created with ID 1, ipv4 table-id 0x1, ipv6 table-id 0x1E000001
*Jul 9 05:32:44.969: %SYS-5-CONFIG_I: Configured from memory by console
*Jul 9 05:32:44.982: %IOSXE_OIR-6-REMSPA: SPA removed from subslot 0/0, interfaces disabled
*Jul 9 05:32:45.013: %SPA_OIR-6-OFFLINECARD: SPA (12xGE-2x10GE-FIXED) offline in subslot 0/0
*Jul 9 05:32:45.235: %SYS-5-RESTART: System restarted --
*Jul 9 05:32:47.691: %IOSXE_OIR-6-INSCARD: Card (fp) inserted in slot F0
*Jul 9 05:32:47.691: %IOSXE_OIR-6-ONLINECARD: Card (fp) online in slot F0
*Jul 9 05:32:47.692: %IOSXE_OIR-6-INSCARD: Card (cc) inserted in slot 0
*Jul 9 05:32:47.692: %IOSXE_OIR-6-ONLINECARD: Card (cc) online in slot 0
*Jul 9 05:32:47.779: %IOSXE_OIR-6-INSSPA: SPA inserted in subslot 0/0
Authentication passed
Router>en
Router#sh inv
*Jul 9 05:33:24.116: Bulk port license Activated
*Jul 9 05:33:24.152: %SPA_OIR-6-ONLINECARD: SPA (12xGE-2x10GE-FIXED) online in subslot 0/0
*Jul 9 05:33:25.750: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/0, changed state to down
*Jul 9 05:33:25.846: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/1, changed state to down
*Jul 9 05:33:25.895: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/2, changed state to down
*Jul 9 05:33:25.954: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/3, changed state to down
*Jul 9 05:33:26.050: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/4, changed state to down
*Jul 9 05:33:26.050: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/5, changed state to down
*Jul 9 05:33:26.050: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/6, changed state to down
*Jul 9 05:33:26.051: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/7, changed state to down
*Jul 9 05:33:26.051: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/8, changed state to down
*Jul 9 05:33:26.051: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/9, changed state to down
*Jul 9 05:33:26.052: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/10, changed state to down
*Jul 9 05:33:26.052: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/11, changed state to down
*Jul 9 05:33:26.052: %LINK-3-UPDOWN: Interface TenGigabitEthernet0/0/12, changed state to down
*Jul 9 05:33:26.053: %LINK-3-UPDOWN: Interface TenGigabitEthernet0/0/13, changed state to down[OK]
NAME: "Chassis", DESCR: "Cisco ASR920 Series - 12GE and 2-10GE - AC model"
PID: ASR-920-12CZ-A , VID: V01, SN: CAT1903U0DM
Solved! Go to Solution.
07-14-2018 01:59 PM
I looked around, it is possible that the FPD image is corrupted. Try and use the command 'upgrade hw-module subslot fpd bundled' to recover the image.
07-14-2018 01:59 PM
07-15-2018 11:27 PM
07-16-2018 02:21 AM
Hello @Georg Pauwen
earlier for the same below command the output for STATUS was "out of service"(failed too many times)............ now its showing OK: (highlighted on red) and all of a sudden the remaining gig ports changed it states to up and down is this normal ????
Router#sh hw-module subslot all oir
Module Model Operational Status
subslot 0/0 12xGE-2x10GE-FIXED ok
Router#sh hw-module subslot all fpd
H/W Field Programmable Current Min. Required
Slot Card Type Ver. Device: "ID-Name" Version Version
0/0 12xGE-2x10GE-FIXED 1.0 N/A N/A N/A
Router#
*Jul 16 08:31:19.286: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/7, changed state to up
*Jul 16 08:31:19.956: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/5, changed state to up
*Jul 16 08:31:19.971: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/6, changed state to up
*Jul 16 08:31:19.986: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/7, changed state to up
*Jul 16 08:31:21.250: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/4, changed state to up
*Jul 16 08:31:21.263: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/5, changed state to up
*Jul 16 08:31:21.274: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/6, changed state to up
*Jul 16 08:31:21.950: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/4, changed state to up
*Jul 16 08:31:24.259: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/5, changed state to down
*Jul 16 08:31:24.263: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/6, changed state to down
*Jul 16 08:31:26.263: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/5, changed state to up
*Jul 16 08:31:26.274: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/6, changed state to up
*Jul 16 08:31:26.950: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/4, changed state to down
*Jul 16 08:31:28.951: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/4, changed state to up
*Jul 16 08:31:38.250: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/4, changed state to down
*Jul 16 08:31:38.950: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/4, changed state to down
*Jul 16 08:31:39.260: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/5, changed state to down
*Jul 16 08:31:39.959: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/5, changed state to down
*Jul 16 08:31:41.259: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/6, changed state to down
*Jul 16 08:31:41.266: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/7, changed state to down
*Jul 16 08:31:41.967: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/7, changed state to down
*Jul 16 08:31:43.986: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/6, changed state to down
*Jul 16 08:31:46.283: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/7, changed state to up
*Jul 16 08:31:46.950: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/5, changed state to up
*Jul 16 08:31:46.968: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/6, changed state to up
*Jul 16 08:31:46.983: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/7, changed state to up
*Jul 16 08:31:48.254: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/5, changed state to up
*Jul 16 08:31:48.267: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/6, changed state to up
*Jul 16 08:31:49.250: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/4, changed state to up
*Jul 16 08:31:49.952: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/4, changed state to up
*Jul 16 08:31:53.254: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/5, changed state to down
*Jul 16 08:31:53.264: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/6, changed state to down
*Jul 16 08:31:53.267: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/7, changed state to down
*Jul 16 08:31:53.955: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/5, changed state to down
*Jul 16 08:31:53.962: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/6, changed state to down
*Jul 16 08:31:53.967: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/7, changed state to down
*Jul 16 08:31:54.251: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/4, changed state to down
*Jul 16 08:31:54.951: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/4, changed state to down
Router#sh ver
Cisco IOS XE Software, Version 03.18.00.SP.156-2.SP-ext
software.
ROM: IOS-XE ROMMON
Router uptime is 39 minutes
Uptime for this control processor is 42 minutes
System returned to ROM by reload
System image file is "bootflash:/asr920-universalk9_npe.03.18.00.sp.156-2.sp-ext.bin"
Last reload reason: PowerOn
export@cisco.com.
License Level: advancedmetroipaccess
License Type: Permanent
Next reload license Level: advancedmetroipaccess
Router# wr mem
Building configuration...
[OK]
shall i try upgrading the FPD image bundle as u suggested ?
