Policing traffic on switch 2960x
mrochac
Cisco friends - my question is, can i setup some sort of class-map with specific ACL set BE queue and only allow this traffic to use a percentage of traffic on the uplink port of switch?
scenario - users use o365, o365 is saturating our traffic, i would like to tag this traffic based on destination ip's and police how much bandwidth it can use.
hope question is clear
6 Replies 6
You can tag it on the 2960 using qos and then police it on the uplink switch.. is that what you are asking?
If this posts answers your question or is helpful, please consider rating it and/or marking as answered.
That is correct, exactly - that being said what do I tag it with CoS value or DSCP value, I'm still new to this... and I tag at ingress port and throttle on egress uplink port correct?
...i must add the following, access switches are 2960x, distribution switches are 4500x - that being said, i cant create object-groups on 2960 i dont think, so how would i go about creating ACL to tag? manual entry i'm stating to get the feeling?
Joseph W. Doherty
From what you've described, if you have some traffic that saturates a link, it would probably be better to deprioritize it rather than police it. This because a policer won't allow such traffic to use otherwise available bandwidth and a policer might not still constrain the traffic enough relative to other traffic.
Regarding you later question about tagging, when possible, use DSCP ToS tags.
...getting a little confused and not sure why. So i created a ACL to filter the traffic for my policy; (MS ip's)
Extended IP access list O365Filter
10 permit ip any 13.107.6.0 0.0.0.254 log
11 permit ip any 40.100.162.0 0.0.0.255
20 permit ip any 13.107.9.0 0.0.0.254 log
30 permit ip any 13.107.18.0 0.0.0.254 log
40 permit ip any 13.107.19.0 0.0.0.254 log
50 permit ip any 13.107.128.0 0.0.3.255 log
60 permit ip any 23.103.160.0 0.0.15.255 log
70 permit ip any 23.103.224.0 0.0.31.255 log
80 permit ip any 40.96.0.0 0.0.255.255 log
90 permit ip any 40.104.0.0 0.0.255.255 log
100 permit ip any 52.96.0.0 0.3.255.255 log
110 permit ip any 111.221.112.0 0.0.7.255 log
130 permit ip any 132.245.0.0 0.0.255.255 log
140 permit ip any 134.170.68.0 0.0.1.255 log
150 permit ip any 150.171.32.0 0.0.3.255 log
160 permit ip any 157.56.232.0 0.0.7.255 log
170 permit ip any 157.56.240.0 0.0.15.255 log
180 permit ip any 191.232.96.0 0.0.31.255 log
190 permit ip any 191.234.140.0 0.0.3.255 log
200 permit ip any 206.191.224.0 0.0.31.255 log
201 permit ip any any
I've attached the ACL to my core4500 ports which is connected to my access switche as follow;
interface TenGigabitEthernet1/1/6
description Catwalk-STK
switchport trunk native vlan 999
switchport trunk allowed vlan 22,31,50,70,71,90,183,666,999
switchport mode trunk
ip access-group O365Filter in
channel-protocol lacp
channel-group 6 mode active
ip dhcp snooping trust
so 5 separate ports (connected to 5 separate Access switches) - ACL is in the "IN" to filter traffic coming into core.
...but.. im getting no hits on ACL...help?
The idea here is to confirm indeed traffic to the following destination is flowing in - so i can then use the ACL and implement in policy as follow;
class-map match-any O365
match access-group name O365Filter
policy-map O365
class O365
set dscp 000
...where i will then apply to my MPLS facing port... am i in the right path?
Not showing how? Reason I ask, sometimes switches don't show "normal" stats when ASIC process packet.
Does access-group also show in port-channel interface?
