ASR1001 interface won't come UP
I need some help with the connection between a ASR1001 and a Catalyst 2960G. The interface on the ASR won't come up, and I am pretty sure this is a configuration issue but I can't figure it out
At first, both interfaces wouldn't come up, but since I have set speed and duplex to 1000/full on both sides, the switch port is up/up but the router port is still down...
Switch configuration :
interface GigabitEthernet0/6
 switchport trunk allowed vlan 425,605
 switchport mode trunk
 speed 1000
 duplex full
 no cdp enable
 spanning-tree bpdufilter enable
Router configuration :
interface GigabitEthernet0/0/0
 no ip address
 ip access-group InFilter in
 speed 1000
 no negotiation auto
 ip virtual-reassembly
interface GigabitEthernet0/0/0.425
 encapsulation dot1Q 425
 ip address x.x.x.x 255.255.255.0
 no ip redirects
 no ip unreachables
 standby 221 ip x.x.x.x
 standby 221 timers msec 250 msec 800
 standby 221 priority 90
interface GigabitEthernet0/0/0.605
 encapsulation dot1Q 605
 ip address x.x.x.x 255.255.255.224
 no ip redirects
 no ip unreachables
Any thoughts, ideas, suggestions...
Is there a debug I could turn on to troubleshoot the L2 on the ASR ?
8 Replies 8
Reza Sharifi
Are these copper or fiber ports?
gigabit copper ports
Did you manage to sort this issue out?
I've currently mocked up a lab environment with an ASR1001-X and a 2960S (10G).
I have a similar setup to yourself but am using 10G between interfaces connected via MM fibre.
Interestingly, i'm not seeing any connectivity either.
I'll upgrade the 2960 to 15. code to see if it makes any difference.
UPDATE: The ASR was set to auto. Setting the remote end to "non-negotiate" FIXED the issue.
you changed it to Auto ? or it was incorrectly set to auto ?
Sorry, we're getting ready to deploy 1001's soon, and I'm trying to see what I should expect, as I've no ideas what kind of anomalies I'll find between XE and XR.
So, did you leave the no negotiate auto on the ASR ?
If it was a fiber link on a 9006, I'd have said try negotiation auto on the ASR. Might be worth a try.
It was "only" a hardware problem on both SFPs (bad serie?!). I had them replaced and now everything works fine.
