ASR1002-X ambiguous QinQ limits
atdp03
Hello.
We faced strange problem, while migrating from single .1q to QinQ, on ASR1002-X.
Initially, we have about 1600 vlans, that we convert to double tagged, using 'vlan per port' scheme.
So, configs changed from:
interface Port-channel1.888
 description v888
 encapsulation dot1Q 888
to:
interface Port-channel1.896
 description vlan 896 qinq
 encapsulation dot1Q 896 second-dot1q 250-3000
Other parts of configs remains the same, except for different 'service-policy type control ', for authenticate users using two vlans, and not Opt82.
After migrating about 560 SVLANs, we faced a problem while deleting or adding encapsulations:
Jan 19 17:03:39: %ASR1000_SPA_ETHER-3-TCAM_QINQ_VLAN_ERROR: SIP0/3: Failed to delete VLAN outer 896 inner 250-3000 to/from interface TenGigabitEthernet0/3/0 (status = 2)
Jan 19 17:05:00: %ASR1000_SPA_ETHER-3-TCAM_QINQ_VLAN_TABLE_FULL: SIP0/1: Failed to add VLAN outer 896 inner 250-3000 to interface TenGigabitEthernet0/1/0
After trimming CVLAN ranges on some previously configured SVLANs, we was able to change encapsulation.
We have no problems with TCAM, as i can see:
show platform hardware qfp active tcam resource-manager usage
Total
TCAM Cell Usage Information
Name                                : TCAM #0 on CPP #0
Total number of regions             : 3
Total tcam used cell entries        : 2546
Total tcam free cell entries        : 521742
Threshold status                    : below critical limit
We also have no problems with idb:
#sh vlans dot1q internal | cou .1Q
Number of lines which match regexp = 1690
#sh idb a
Maximum number of Software IDBs 131072.  In use 16443.
Maximum number of Micro Software IDBs 49152.  In use 0.
                       HWIDBs     SWIDBs          uHWIDBs    uSWIDBs
Active                     25       5214                0          0
Inactive                   15      11229                0          0
Dirty                       0          0                0          0
Total IDBs                 40      16443                0          0
Size each (bytes)        4880       1920             3784        616
Total bytes            195200   31570560                0          0
So, question is: are this some hard limitation, or we can tweak something?
lukas.tribus
By default the ASR1000 appears to handle this in the SPA, which has limited scalability especially when it comes to specific second-dot1q matches.
Use the following command to handle this in the QFP instead:
hw-module subslot slot/subslot ethernet vlan unlimited
Read more about this here:
https://www.cisco.com/c/en/us/td/docs/interfaces_modules/shared_port_adapters/configuration/ASR1000/modular_ethernet_linecard/b-ASRmelcconf/ASRmelcconf_chapter_011.html#task_1233716
Fun fact: if you hit this TCAM exhaustion problem in older releases, you don't even get this error message. This subinterface will simply not work.
Also consider using "second-dot1q any" instead of a specific c-vlan range if possibile, as this will use very little TCAM ressources.
