OSPF issues on ASR920 and C2960L
sjewhurst
Hi folks,
Long time reader, first time asker, so lets dive straight in.
We're migrating our core from ME3600X to ASR920. We've two acting as our core and two C2960s hanging off for LAN usees. I've configured a couple of BDIs as gateways for our firewalls and "trunked" them (as best you can) across to the second ASR920 and down to the switches. When the Cores are connected via just the TenGigE link, OSPF and LDP come up and adjacencies form, but when I connect the Port-Channel down to the Switches, OSPF and LDP go down. L3 across the point-to-point link works but everything else is only sporadically reposnding to ping (??? weird..).
If I disconnect the Port-Channel, everything comes back with no issues.
I have a feeling something is looping in L2, or I'm missing something when it comes to the bridge-domain configuration but I'm not used to troubleshooting service-instances. Config as follows:
core1 (& core2)
spanning-tree mode mst
spanning-tree mst configuration
 instance 1 vlan 1-2024
 instance 2 vlan 2025-4094
spanning-tree mst 1 root pri
spanning-tree mst 2 root sec
bridge-domain 900
bridge-domain 3850
interface bdi 900
 description Core: core1 <-> core2 vlan 900 Routing
 ip address 10.10.10.2 255.255.255.254
 ip ospf 41678 area 0
 ip ospf authentication message-digest
 ip ospf message-digest-key 1 md5 authme
 ip ospf network point-to-point
 ip ospf hello-interval 3
 ip ospf dead-interval 10
 mpls ip
 bfd interval 250 min_rx 250 multiplier 4
interface bdi 3850
 description Core: core1 <-> fw-1 Po1.3850
 vrf forwarding MGMT_VPN
 ip address 172.19.15.242 255.255.255.240
 standby bfd
 standby 1 ip 172.19.15.241
 standby 1 preempt
 ip ospf 100 area 0
interface Port-channel 1
 description Port-channel to access1
 service instance 900 ethernet
  encapsulation dot1q 900
  rewrite ingress tag pop 1 symmetric
  bridge-domain 900
 service instance 3850 ethernet
  encapsulation dot1q 3850
  bridge-domain 3850
interface GigabitEthernet0/0/10
 description Core: core1 <-> access1
 channel-group 1 mode active
interface GigabitEthernet0/0/11
interface TenGigabitEthernet0/0/24
 description Core: core1 <-> core2 Te0/0/24
  bridge-domain 900
  bridge-domain 3850
router ospf 100 vrf MGMT_VPN
 router-id 172.19.15.241
 nsf cisco
 passive-interface default
 no passive-interface bdi3850
router ospf 200
 nsf cisco
 router-id 10.10.10.2
 max-metric router-lsa on-startup 30
 auto-cost reference-bandwidth 100000
 no passive-interface bd900
access1 (& access2)
interface GigabitEthernet0/51
description access1 <-> access2 g0/51
switchport mode trunk
channel-group 2 mode active
interface GigabitEthernet0/52
description access1 <-> access2 g0/52
description Port-channel to core1
switchport trunk allowed vlan 666,900,3850
switchport trunk native vlan 666
interface Port-channel 2
description Port-channel to access2
Topology
|    core1   |----te0/0/24---|    core2    |
--------------    <-OSPF->    --------------
      || Po1      <-HSRP->          ||
      ||                        Po1 ||
|   access1  | =====Po2======|   access2   |
 Any thoughts on this? Thanks!
sjewhurst
I located the issue while attending site.
It seemed that access2 had not taken the mst configuration and was still running PVST. Given that PVST maps to MST0 it was causing a bunch of issues.
Once I reconfigured spanning-tree, everything came back to life and stablised, ports began to block.
Giveaway was the output below:
access1-r1-cq2#sh span vlan 900
MST1
  Spanning tree enabled protocol mstp
  Root ID    Priority    24577
             Address     00f8.2c44.bf80
             This bridge is the root
             Hello Time   2 sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    24577  (priority 24576 sys-id-ext 1)
Interface           Role Sts Cost      Prio.Nbr Type
Po1                 Desg FWD 10000     128.56   P2p
Po2                 Desg FWD 10000     128.64   P2p Bound(PVST)
vs access2
access2-r2-cq2#sh span vlan 900
VLAN0900
  Spanning tree enabled protocol rstp
  Root ID    Priority    32768
             Cost        3
             Port        64 (Port-channel2)
  Bridge ID  Priority    33668  (priority 32768 sys-id-ext 900)
             Address     00f8.2c77.8780
             Aging Time  300 sec
Po1                 Desg FWD 3         128.56   P2p
Po2                 Root FWD 3         128.64   P2p Peer(STP)
Even though it says quite clearly rstp, I somehow missed this everytime and caught it on the P2p Peer protocol. Lesson in observation for me.
Note also that I moved the MST root off the ASR920 and onto the C2960, as it will be handling the most vlans.
5 Replies 5
Francesco Molino
Can you share show spanning-tree vlan 900 and 3850 output from all equiments?
Can you shutdown Po1 between Core2 and Access2 and do the same output as before?
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Francesco,
I should be on-site with the devices later today and I will capture this at that point. However from my testing last week, I did note that none of the devices adopted a Blocking port state which I'd exptected to see on the Port-channel on one of the 2960s
One thing has just occured to me. Under the service-instance I am using:
This pops the vlan tag on ingress - so surely this would break MST? In my head it puts the packet on the bridge domain, but it essentially has no vlan?
EDIT: For completeness as written here
  • Layer 2 forwarding is based on the bridge domain ID and the destination MAC address. The frame is forwarded to an EFP if the binding between the bridge domain, destination MAC address, and EFP is known. Otherwise, the frame is flooded to all the EFPs or ports in the bridge domain
sjewhurst
MST1
vs access2
VLAN0900
             Cost        3
             Aging Time  300 sec
Ok you found out it yourself, that's why I wanted to get the show spanning-tree output.
Happy that you solved your issue
Francesco
