asr1004 doesn't export netflow statistic from vrf interface. 122-33.XNF2
Hello, colleagues.
I have asr routers with flow export configured. Flow-collector with ip address 10.10.129.114 receives statistic from exporter 10.10.132.144. But in fact traffic from router to flow-collector goes not over interface in vrf but over global routing table.
So routers are sending statistic with vrf source, but not over vrf interface. Is it some known bag?
Software asr1000rp2-advipservicesk9.02.06.02.122-33.XNF2
asr1#show run | in flow
ip flow ingress
ip flow ingress
ip flow ingress
ip flow ingress
ip flow ingress
ip flow ingress
ip flow-export version 5 peer-as bgp-nexthop
ip flow-export destination 10.10.129.114 5000 vrf Mgmt-intf
asr1#sho vrf Mgmt-intf
  Name                             Default RD          Protocols   Interfaces
  Mgmt-intf                        <not set>           ipv4,ipv6   Gi0
#show ip flow export
Flow export v5 is enabled for main cache
  Export source and destination details :
  VRF ID : 4085
    Source(1)       10.10.132.144 (GigabitEthernet0)
    Destination(1)  10.10.129.114 (5000)
  Version 5 flow records, peer-as bgp-nexthop
  467558004 flows exported in 16544602 udp datagrams
  0 flows failed due to lack of export packet
  0 export packets were sent up to process level
  0 export packets were dropped due to no fib
  0 export packets were dropped due to adjacency issues
  0 export packets were dropped due to fragmentation failures
  0 export packets were dropped due to encapsulation fixup failures
  0 export packets were dropped enqueuing for the RP
  0 export packets were dropped due to IPC rate limiting
  0 export packets were dropped due to Card not being able to export
#show interfaces gigabitEthernet 0
GigabitEthernet0 is up, line protocol is up
  Hardware is RP management port, address is 8843.e177.cd80 (bia 8843.e177.cd80)
  Description: "MANAGEMENT"
  Internet address is 10.10.132.144/27
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive set (10 sec)
  Full Duplex, 100Mbps, link type is auto, media type is RJ45
  output flow-control is unsupported, input flow-control is unsupported
  Last input 00:00:14, output 00:00:00, output hang never
  Last clearing of "show interface" counters 1d17h
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     104345 packets input, 9015921 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 watchdog, 0 multicast, 0 pause input
     78113 packets output, 7906690 bytes, 0 underruns
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
Giuseppe Larosa
hello Vladimir,
it looks like unsupported see
https://supportforums.cisco.com/thread/2048414?tstart=0
Hope to help
Giuseppe
gephelps
Giuseppe provided a link to the other thread, but this is not supported on the ASR1000.
12.2(33)XNF brought support for Netflow Export to a destination in a VRF for the ASR1000, but it is not supported on the Gig0 interface.
If you try to configure the source as Gig0 there was a check put in which informs you this is not supported:
Router(config)#ip flow-export source gig0
%Interface GigabitEthernet0 cannot be used as an exporter source!
Netflow collection and export happens directly on the ESP and does not require the RP to function. The  ESP has no way to interact with the Gig0 interface directly since the management interface is part of the RP.
I just hit this problem on an ASR1002-X, google the error and hit your very useful explanation! Thanks George! Looks like I'll be configuring Gig0/0/5 as the management interface rather than Gig0 so we can netflow exports out of the router.
Thanks again!
