help/ajuda - stack 3750x
andersonpuliafico
Community Member
Good morning to all
I'm having problems setting up 2 3750x switches in stack.
On switch 1 I set everything ok, switch 2 I leave with no configuration, I put the cables as I usually stack configured 3750 V2 successfully ... but the 3750x does not work.
Through the command switch sw I check that the master switch is my first, but it  does not recognize the second switch (this second should be the member) is connected.
Switch # sh switch
Switch / Stack Mac Address: e02f.6d48.8d00
H / W Current
Switch # Role Mac Address Priority Version State
* 1 3 1 Master Ready e02f.6d48.8d00
I put the console cable to the switch 2 and the same thing happens, it is as master and does not recognize that there is another switch connected through the cable stack.
Switch # sh switch
Switch / Stack Mac Address: b0fa.eb77.2f80
H / W Current
* 2 Master b0fa.eb77.2f80 1 1 Ready
I changed priorities and also changed the number of switches through the command renumber also without success, as well as the change to another cable, eliminating also the possibility of damage of cable and I took it off and replaced it several times just to check.
IOS versions are also the same.
I used the command found in official material switch "X" stack port "X" enable on the ports that are down as well ,and it did not work.
Does anyone know what could it be? Is it missing some command?
Thank you
Anderson Puliafico
Bom dia a todos
Estou com problemas para configurar 2 switches 3750x em stack.
No switch 1 eu configuro tudo ok, no switch 2 eu deixo sem nenhuma configuração, coloco os cabos stack normalmente como já configurei 3750 V2 com sucesso...porém no 3750x não funciona.
Através do comando sw switch verifico que o master é o meu primeiro switch, porém ele sequer reconhece o segundo switch (este segundo deveria ser o member) está conectado.
Switch#sh switch
Switch/Stack Mac Address : e02f.6d48.8d00
H/W Current
Switch# Role Mac Address Priority Version State
*1 Master e02f.6d48.8d00 3 1 Ready
Coloco o cabo de console no switch 2 e acontece o mesmo, ele está como master e não reconhece que há outro switch conectado através do cabo stack.
Switch#sh switch
Switch/Stack Mac Address : b0fa.eb77.2f80
                                          H/W   Current
*2       Master b0fa.eb77.2f80     1     1       Ready
Alterei as prioridades e também alterei o número dos switches através do comando renumber também sem sucesso, assim como a troca por outro cabo, eliminando também a possibilidade de cabo danificado e tirei e recoloquei diversas vezes por desencargo.
As versões do IOS também são as mesmas.
Usei o comando que achei no material oficial switch "X" stack port "X" enable nas portas que estão como down e também não deu certo.
Alguem sabe o que poderia ser? Está faltando algum comando?
Obrigado
Anderson Puliafico
Reza Sharifi
Do you have the same IOS version loaded on both devices?
Are you using the stacking cable that comes in the box?
Did you make sure the stacking cables inserted correctly and the scrows are tight?
13 Replies 13
Reza Sharifi
Hi Reza
Both switches have the same IOS. Version 12.2 (55) SE5
I can not tell if I'm just using the cables that came in the box, because in my company we have a box full of cables stack. Do you know if there are cable stack variations? (except for length)
The cables are very tight  and well adjusted.
Additional information that I got in the log:
"* Feb 28 21:04:22:% STACKMGR-4-STACK_LINK_CHANGE: Stack Port 1 Switch 1 has changed to state DOWN
* Feb 28 21:04:22:% STACKMGR-4-STACK_LINK_CHANGE: Stack Port 2 Switch 1 has changed to state DOWN "
I used the command switch "X" stack port "X" enable on the the ports and it still does not work. The switches do not see each other and both stay as master and there is no member.
Hi Reza
Ambos switches possuem mesmo IOS. Version 12.2(55)SE5
Não sei dizer se estou usando exatamente os cabos que vieram na caixa, pois na minha empresa temos uma caixa cheia de cabos stack. Você sabe me dizer se existem variações de cabo stack? (com exceção de comprimento)
Os cabos estão bem apertados/ajustados.
Uma informação adicional que peguei pelo log:
“*Feb 28 21:04:22: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 1 Switch 1 has changed to state DOWN
*Feb 28 21:04:22: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 2 Switch 1 has changed to state DOWN”
Utilizei o comando switch “X” stack port “X” enable nas portas e mesmo assim não funciona. Os switches não se enxergam e ambos ficam como master e não há nenhum member.
SHIBI V DEV
Level 3
Level 3
First confirm the IOS of the both Switches are matching , if there is mismatch, try to load same IOS in both Switch and connect stack cable as mentioned
                           First Switch Stack2 Port----------to -----  Second Switch Stack 1 Port
                           First Switch Stack1 Port----------to -----  Second Switch Stack 2 Port
Hi Shibi
And the wires were already connected in this order you said.
Additional information that i got in the log:
Hi Shibi
E os cabos já estavam conectados nessa ordem que você falou.
Those error messages are related to hardware, either the cable or the stack port is faulty.
I will recommend you to open up a case and request a RMA
It's strange because I have 3 switches with the same problem ...
É estranho pois tenho 3 switches com o mesmo problema...
Anderson,
      I had issue while connecting 7 Switches in stack.I will explain the Steps i did to resolve the issue
- Removed all Stack cables from Master and Made its priority as 15 ,and created all the VLANs in Master
-Erased running config from Second Switch and connected stack like
      Then it joined to stack as Member
-Then we added third Switch like this
                           Second Switch Stack2 Port----------to -----  Third Switch Stack 1 Port
                             Third Switch Stack2 Port----------to -----  First Switch Stack 1 Port
Then third Switch joined to Stack.  Like this each Switch added in ring and it worked.
Diego Romero
Level 2
Level 2
Make sure you have the same IOS images in both switches.
Remember that the switch must be added turned off to the stack then it will powered on.
Make sure the cables are working fine, try play around with them and see show stack ports.
The IOS are the same, the cables are placed with the second switch off and I tested several cables and it did not work.
InayathUlla Sharieff
Hi Anderson,
I just wanted to share the managing switch stack portion of the
configuration guide with you concerning adding or removing stack
members. As discussed when adding removing switch we recommend powering
down the switch in question.
Managing switch stacks
http://www-cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_25_see/configuration/guide/swstack.html#wp1192957
Make sure the switches that you add to or remove from the switch stack
are powered off.
After adding or removing stack members, make sure that the switch stack
is operating at full bandwidth (32 Gbps). Press the Mode button on a
stack member until the Stack mode LED is on. The last two port LEDs on
all switches in the stack should be green. Depending on the switch
model, the last two ports are either 10/100/1000 ports or small
form-factor pluggable (SFP) module ports. If, on any of the switches,
one or both of the last two port LEDs are not green, the stack is not
operating at full bandwidth.
�Adding powered-on switches (merging) causes the stack masters of the
merging switch stacks to elect a stack master from among themselves. The
re-elected stack master retains its role and configuration and so do its
stack members. All remaining switches, including the former stack
masters, reload and join the switch stack as stack members. They change
their stack member numbers to the lowest available numbers and use the
stack configuration of the re-elected stack master.
�Removing powered-on stack members causes the switch stack to divide
(partition) into two or more switch stacks, each with the same
configuration. This can cause an IP address configuration conflict in
your network. If you want the switch stacks to remain separate, change
the IP address or addresses of the newly created switch stacks. If you
did not intend to partition the switch stack:
* a. *Power off the newly created switch stacks.
* b. *Reconnect them to the original switch stack through their
StackWise ports.
* c. *Power on the switches.
For more information about cabling and powering switch stacks, see the
"Switch Installation" chapter in the hardware installation guide.
Also MAke sure you have configured the cmd as suggested:
switch 1 stack port 1 enable/disbale.
Inayath
Thanks for sharing the article, I read the text, and made new tests without success.
HI,
Can you try replacing the stack cables?
Inayath
paulwoodsy
Community Member
Hi Anderson,
Did you manage to resolve your stack issue?
I too have encountered the same issue, in a nutshell:-
I have 2 x 3750x switches both running identical IOS -  12.2(55)SE5 & both connected using stackwise cables.
WS-C3750X-12S is priority 15 & switch number 1
ws-c3750x-24 is priority 1 & is switch number 2
I have enabled each switch stack port via "switch X stack port X enable"
I have replaced the stackwise cables. Reloaded on numerous occassions but still no sign of the stack appearing?
They appear as seperate Masters....
Any help here would be appreciated? I'm thinking it maybe something to do with the IOS revision so next step maybe to downgrade/upgrade 12.2(55)SE5...
