ASR920 VLAN tagging
jatkins03
Can anyone tell me why I can't pass traffic to a trunked port on a Cisco 2960 or 3560 with this config running on an ASR920?  I can pass untagged traffic....BDI1 but nothing for VLAN's 10,20 or 30.  Standard switchport mode trunk config on the switches.  Thanks in advance!
Switch#show run
Building configuration...
Current configuration : 6714 bytes
version 16.8
service nagle
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
service unsupported-transceiver
no platform punt-keepalive disable-kernel-core
platform bfd-debug-trace 1
platform xconnect load-balance-hash-algo mac-ip-instanceid
platform tcam-parity-error enable
platform tcam-threshold alarm-frequency 1
hostname Switch
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
aaa new-model
no ip bootp server
ip domain name BLANK
sdm prefer default
diagnostic bootup level minimal
redundancy
bridge-domain 2
transceiver type all
monitoring
cdp run
lldp run
policy-map mark-default
class class-default
set dscp default
interface GigabitEthernet0/0/0
no ip address
negotiation auto
service instance 1 ethernet
encapsulation untagged
bridge-domain 1
interface GigabitEthernet0/0/5
no ip address
media-type auto-select
negotiation auto
bridge-domain 1
service instance 10 ethernet
encapsulation dot1q 10
bridge-domain 10
service instance 20 ethernet
encapsulation dot1q 20
bridge-domain 20
service instance 30 ethernet
encapsulation dot1q 30
bridge-domain 30
i
interface TenGigabitEthernet0/0/13
description Uplink to ISP
ip address 10.x.x.x 255.255.255.252
negotiation auto
interface BDI1
description LAN
ip address 10.17.0.1 255.255.254.0
interface BDI10
description STAFF VLAN
ip address 10.17.10.1 255.255.255.0
interface BDI20
description STUDENT VLAN
ip address 10.17.20.1 255.255.252.0
interface BDI30
description GUEST VLAN
ip address 10.17.28.1 255.255.252.0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10x.x.x
mlund
Level 7
Level 7
You are missing the rewrite command, it will not work without it.
/Mikael
luis_cordova
Thanks for the reply.  I saw this post and thought that's what I configured, but it's still not working.
mlund
Level 7
Level 7
/Mikael
Thank you, mlund, for putting me on the right track.  This worked:
no ip address
negotiation auto
bridge-domain 1
rewrite ingress tag pop 1 symmetric
bridge-domain 10
bridge-domain 20
bridge-domain 30
