Assign IP address to switch
k_bhavsar
Hi All,
I have one switch connected to network. Currently IP address is assigned though DHCP. I want to assign same IP address statically though remote.
How can I assign static IP address.
Switch is cisco 2960G.
current config. on switch.
intreface vlan 1
ip address dhcp
Seb Rupik
Hi Krunal,
The syntax is
ip address
eg:
interface vlan1
  ip address 192.168.25.1 255.255.255.0
cheers,
Seb.
devils_advocate
Level 7
Level 7
Please don't use Vlan1, pick another Vlan for your management.
Make sure you do a no shut on the Vlan Interface once you have assigned the IP address. The VlanID also needs to be allowed across any trunk links before it will show as Up.
Static routing is supported on Catalyst 2960-L switches
Step 1 enable Enables privileged EXEC mode.
Example:
Switch> enable
• Enter your password if prompted.
configure terminal Enters the global configuration mode.
Example:
Switch# configure terminal
Step 2
ip route prefix mask {address | interface} Establish a static route.
[distance]
Step 3
Example:
Switch(config)# ip route prefix mask
gigabitethernet 1/0/4
end Returns to privileged EXEC mode.
Example:
Switch(config)# end
Step 4
Displaysthe currentstate of the routing table
to verify the configuration.
show ip route
Example:
Switch# show ip route
Step 5
(Optional) Saves your entries in the
configuration file.
copy running-config startup-config
Example:
Switch# copy running-config
Step 6
startup-config
