01-07-2015 03:59 AM - edited 03-07-2019 10:07 PM
i want to connect my new allied telesyn 8000s Access switch with cisco catalyst 2960x series switch.
both are configured in same vlan(vlan1). iam able to communicate between with ethernet ports but while connecting sfp modules communicate failed.
is there any encapsulation,trunking req in switches,
help me to clear the issue. thanks in advance.
01-07-2015 04:37 AM
Hello
"both are configured in same vlan(vlan1). iam able to communicate between with ethernet ports but while connecting sfp modules communicate failed."
Are these switches already connected to each other via access ports and you wish to connect instead via sfp modules?
If so are the sfp's compatible -
Media type (fibre/gbic) -
What cabling is being used
res
Paul
01-07-2015 10:26 PM
Hi Sir,
now one access port connected from cisco switch to AT-Media Convertor, and terminated at AT-switch with fiber optic module(SFP Module),
In both the places we using MM SFP MODULES
Media Type:Fiber
Cabling : MM OFC
plz conforme me how to check the compatibility between these two SFP's
05-02-2018 08:52 PM
If the default configuration is satisfactory, the switch does not need further configuration. You can use any of these management options to change the default configuration:
Start the Network Assistant application, which is described in the getting started guide. Through this GUI, you can configure and monitor a switch cluster or an individual switch.
Use the CLI to configure the switch as a member of a cluster or as an individual switch from the console.
Use the Cisco Prime Infrastructure application.
