asymmetrical routing BGP - nexus 7ks
Kumar99
Hi All ,
I am testing the below topology and need inputs from experts on how to stop asymmetrical routing .
As per the above diagram ,
Traffic from LAN to WAN &&& WAN to LAN of Data centers is as below
LAN subnet of data center 1  <----> nexus 7ks  (DC1)  <---> EBGP  <----> Cisco ACI (DC1 )  <---> WAN
LAN subnet of data center 2  <----> nexus 7ks  (DC2)  <---> EBGP  <----> Cisco ACI (DC2 )  <---> WAN
LAN to LAN communication between DC's is as below
LAN subnet of data center 1  <----> nexus 7ks  (DC1)  <---> DCI LINK (EBGP)   <----> nexus 7ks  (DC2)  <---> LAN subnets of Data Center 2
Asymmetrical routing happens if
LAN subnet of Data center 1 Nexus 7ks  --- EBGP --- Cisco ACI (Data center 1 )  -------DCI connectivitiy ------ ( Data center 2) Cisco ACI  ----EBGP Nexus 7ks ( Data center 2) and same is applicable from lan subnets of Data center 2 to lan subnets of Data center 1 .
Can somebody give configuration exmaple to stop asymmetrical routing as lit leads to performance issues .
Can we use BGP community or prefix list or some other options to stop asymmetrical routing in the above case.
Many Thanks
6 Replies 6
nazimkha
HI Kumar,
Are you using ACI multipod or multisite for DCI ?
Is the DCI between the ACI a L3OUT ?
Hi Nazimkha ,
Thank you for the reply ..
I am not sure how about the cisco ACi config as these managed by 3rd party .
Cisco ACI established ebgp from the leaf switches to nexus 7ks . This is the info I had with me.
Can we use prefix-list or community on nexus 7ks to influence in and out traffic ?
Many Thanks..
You can block the BGP advertisement to the ACI fabric using prefix-lists and only advertise via the DCI link between the Nexus 7K. Bear in mind that dynamic routing with BGP is supported only from certain N7K releases.
I would collaborate with the ACI team and design as per Cisco Validated design.
Hi if I block bgp advertisement towards Cisco ACI then LAN subnets can not go to Wan n/w and vice-versa..bgp advertisements should not go through DCI link of Cisco ACIs .....Many Thanks
Basically you should advertise your lan subnets with worse metric toward Cisco ACI. We do that by as-path prepending of your AS number on Nexus7k toward Cisco ACI. Similar action should be done at DC2 Nexus7k. After path over Cisco ACI would be less preferable.
ip prefix-list 100 permit 10.10.10.0/24
ip prefix-list 100 permit 10.10.20.0/24
ip prefix-list 100 permit 10.10.30.0/24
route-map <name of route-map> permit 10
  match ip prefix-list 100
  set as-path prepend <your AS> <your AS> <your AS>
neighbor <Cisco ACI> route-map <name of route-map> out
Best regards,
Abzal
bjornarsb
Level 4
Level 4
The configuration is not Complete, but it gives you some information of how you can use BGP attributes (as-path and local preference) to avoid asymetric routing.
Datacenter 1
DC1_NX1:
BGP peering interface:
interface loopback 1
 ip address x.x.x.x 255.255.255.255
router bgp 300
neighbor 9.9.9.9 remote-as 500
neighbor 9.9.9.9 description Cisco ACI
neighbor 9.9.9.9 route-map trafic-in in
neighbor 9.9.9.9 route-map trafic-out out
network 10.10.10.0 mask 255.255.255.0
network 10.10.20.0 mask 255.255.255.0
network 10.10.30.0 mask 255.255.255.0
route-map trafic-in permit 100
set metric 0
set local-preference 90
route-map trafic-out permit 1000
set as-path prepend 300 300
DC1_NX2:
router bgp 300
neighbor 3.3.3.3 remote-as 700
neighbor 3.3.3.3 description DC2-NX1-EBGP
neighbor 3.3.3.3 route-map prefered-path-in in
neighbor 7.7.7.7 remote-as 500
neighbor 7.7.7.7 description Cisco ACI
neighbor 7.7.7.7 route-map trafic-in in
neighbor 7.7.7.7 route-map trafic-out out
set metric 0
set local-preference 75
set as-path prepend 300 300 300 300
route-map prefered-path-in permit 100
set metric 0
set local-preference 100   (100 is default)
Datacenter 2:
DC2_NX1:
router bgp 700
neighbor 4.4.4.4 remote-as 300
neighbor 4.4.4.4 description DC1-NX2-EBGP
neighbor 4.4.4.4 route-map prefered-flow-in in
neighbor 8.8.8.8 remote-as 500
neighbor 8.8.8.8 description Cisco ACI
neighbor 8.8.8.8 route-map trafic-in in
neighbor 8.8.8.8 route-map trafic-out out
network 20.20.10.0 mask 255.255.255.0
network 20.20.20.0 mask 255.255.255.0
network 20.20.30.0 mask 255.255.255.0
set metric 0
route-map prefered-flow-in permit 100
set metric 0
DC2_NX2:
router bgp 700
neighbor 6.6.6.6 remote-as 700
neighbor 6.6.6.6 description DC2-NX1-IBGP
neighbor 8.8.8.8 description Cisco-ACI-EBGP
set metric 0
BR
bjornarsb
