AUTHENTICATION_FAIL
ag2019
switch type 2960-x shows this message while working:
%ILET-1-AUTHENTICATION_FAIL: This Switch may not have been manufactured by Cisco or with Cisco's authorization. This product may contain software that was copied in violation of Cisco's license terms. If your use of this product is the cause of a support issue, Cisco may deny operation of the product, support under your warranty or under a Cisco technical support program such as Smartnet.
Please advise how can I stop this message.
Deepak Kumar
This is well-known bug https://bst.cloudapps.cisco.com/bugsearch/bug/CSCur56395/?rfs=iqvred
Try to upgrade the IOS.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
balaji.bandi
adding to other post, can post show version.
BB
SW#sh ver
Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.0(2a)EX5, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Mon 16-Feb-15 08:16 by prod_rel_team
ROM: Bootstrap program is C2960X boot loader
BOOTLDR: C2960X Boot Loader (C2960X-HBOOT-M) Version 15.2(4r)E3, RELEASE SOFTWARE (fc4)
test_bench77 uptime is 1 day, 21 hours, 18 minutes
System restarted at 12:08:37 UTC Mon Mar 4 2019
System image file is "flash:c2960x-universalk9-mz.150-2a.EX5.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960X-48LPD-L (APM86XXX) processor (revision H0) with 524288K bytes of memory.
Last reset from power-on
1 Virtual Ethernet interface
1 FastEthernet interface
50 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
* 1 52 WS-C2960X-48LPD-L 15.0(2a)EX5 C2960X-UNIVERSALK9-M
Hello
Following these instructions should assist  - Here
Kind Regards
Paul
