10-01-2014 04:32 AM - edited 03-07-2019 08:56 PM
Im receiving % Authorization failed. in some show commands that should show my the state of switches in VSS...
For example:
VSS#sh swit virtual role
Executing the command on VSS member switch role = VSS Active, id = 1
RRP information for Instance 1
Valid Flags Peer Preferred Reserved
Count Peer Peer
TRUE V 1 1 1
Switch Switch Status Preempt Priority Role Local Remote
Number Oper(Conf) Oper(Conf) SID SID
LOCAL 1 UP FALSE(N ) 120(120) ACTIVE 0 0
REMOTE 2 UP FALSE(N ) 100(100) STANDBY 9708 829
Peer 0 represents the local switch
Flags : V - Valid
In dual-active recovery mode: No
I can only see the state from the view of the ACTIVE switch but not from the view of the STANDBY switch.
For reference my AAA authorization config:
aaa authorization config-commands
aaa authorization exec default group ACSServer1
aaa authorization commands 1 default group ACSServer1 local
aaa authorization commands 15 default group ACSServer1 local
Any recommendetions how to solve this?
Thank you in advance.
Marek
10-07-2014 04:17 AM
Any ideas? 😞
When I remove the authorization commands, then everything seems ok - but it have to be another way... or?
Thanks.
Marek
10-08-2014 02:14 AM
Ok, if someone has the same issue then here is the bug id for this: CSCud74480
Marek
