Auto-Failover between 2 ISPs
balbeer.singh84
Community Member
I have 2 ISPs & configured my interfaces as below :
WAN INTERFACE 1 :-
interface GigabitEthernet0/1
description TCL_WAN
ip address 116.212.176.2 255.255.255.224
ip nat outside
ip virtual-reassembly in
ip policy route-map TCL
duplex full
speed 100
crypto map clientmap
WAN INTERFACE 2 :-
interface GigabitEthernet0/2
description BHARTI_WAN
ip address 61.95.191.54 255.255.255.252
ip nat outside
ip policy route-map BHARTI
duplex full
speed 100
LAN INTERFACE :-
interface GigabitEthernet0/0
description LAN_INTERFACE
ip address 192.168.32.1 255.255.255.224
ip nat inside
duplex full
speed 100
The Auto-Failover configuration is :-
ip sla 1
icmp-echo 203.124.230.12 source-ip 116.212.176.2
frequency 5
ip sla schedule 1 life forever start-time now
track 1 ip sla 1 reachability
delay down 5 up 30
track 2 interface GigabitEthernet0/2 ip routing
delay down 5 up 5
Default IP Routes are :-
ip route 0.0.0.0 0.0.0.0 116.212.176.1 track 1          //Primary WAN
ip route 0.0.0.0 0.0.0.0 61.95.191.53 250 track 2     //Backup WAN
Please tell me whether TRACK 2 is also really needed for my requirement OR only Track 1 will be helpful. What will be the impact of Track 2? Please suggest.
-Balbeer Singh.
cadet alain
only track 1 is needed but you should modify the IP SLA like this:
no ip sla 1
ip sla 1
icmp-echo 203.124.230.12 source-interface GigabitEthernet0/0
frequency 5
I have a question though, why are you doing PBR on inbound WAN traffic ? Shouldn't it be on the LAN interface instead ?
Regards.
Alain
cadet alain
no ip sla 1
ip sla 1
frequency 5
Regards.
Alain
Hi Alain,
Thanks for the reply. Please tell me what can be the impact of Track 2 ?
I faced one problem in which both the WAN 1 was down which made Track 1 down but when WAN 1 came up, the Track 1 in the router was not up. So, I had to add the another default route entry manually as ip route 0.0.0.0 0.0.0.0 116.212.176.1. After that the Track 1 came up. Why this was happened? Please suggest. After adding this route, the entries in the router were :
Please Suggest.
-Balbeer Singh.
My suggestion is to use the source-interface in the IP SLA object and if it is still failing then you can either:
- put a host route for the destination that IP SLA is pinging with a next-hop on the primary interface
-configure local PBR for ICMP traffic destined to the host IP SLA is pinging
Regards.
Alain
