Auto QoS 4 settings fail on 6500 series sup 720 and 32 and need assistance figuring out why.
Preston Kilburn
Hello all, I have a large corporate campus that we are imminently implementing QoS on.  I would like to maintain as much of the SRND AutoQoS 4 settings as possible.  I have placed the following configs into the supervisors and it takes the config.  I am running 6500 supervisors (720 and 32) on version s3223-advipservicesk9_wan-mz.122-33.SXI3.bin.  However when I go to the te5/x (Sup 720) and ge5/x (Sup 32) and try and apply the policies in either inbound or outbound it gives the following error:
ge5/1# service-policy input AutoQos-4.0-Input-Policy
match cos is not supported for this interface in the input direction
ge5/1#  service-policy output AutoQos-4.0-Output-Policy
match cos is not supported for this interface in the output direction
The configs I copied from autoqos 4 are below.  The only things I removed were policing of the pq (  police cir percent 30 bc 33 ms) and Dynamic Buffer Limiting (dbl) because these commands appear to not be supported on the version I'm running (s3223-advipservicesk9_wan-mz.122-33.SXI3.bin)
class-map match-all AutoQos-4.0-Scavenger-Classify
 match access-group name AutoQos-4.0-ACL-Scavenger
class-map match-all AutoQos-4.0-Signaling-Classify
 match access-group name AutoQos-4.0-ACL-Signaling
class-map match-any AutoQos-4.0-Priority-Queue
 match cos  5
 match dscp ef
 match dscp cs5
 match dscp cs4
class-map match-all AutoQos-4.0-VoIP-Data-Cos
 match cos  5
class-map match-any AutoQos-4.0-Multimedia-Stream-Queue
 match dscp af31
 match dscp af32
 match dscp af33
class-map match-all AutoQos-4.0-Network-Mgmt
 match dscp cs2
class-map match-all AutoQos-4.0-VoIP-Signal-Cos
 match cos  3
class-map match-any AutoQos-4.0-Multimedia-Conf-Queue
 match cos  4
 match dscp af41
 match dscp af42
 match dscp af43
 match access-group name AutoQos-4.0-ACL-Multimedia-Conf
class-map match-any AutoQos-4.0-Transaction-Data
 match dscp af21
 match dscp af22
 match dscp af23
class-map match-all AutoQos-4.0-Network-Ctrl
 match dscp cs7
 match dscp cs1
class-map match-all AutoQos-4.0-Default-Classify
 match access-group name AutoQos-4.0-ACL-Default
class-map match-any AutoQos-4.0-Signaling
 match dscp cs3
 match cos  3
class-map match-any AutoQos-4.0-Bulk-Data-Queue
 match cos  1
 match dscp af11
 match dscp af12
 match dscp af13
 match access-group name AutoQos-4.0-ACL-Bulk-Data
class-map match-all AutoQos-4.0-Transaction-Classify
 match access-group name AutoQos-4.0-ACL-Transactional-Data
class-map match-all AutoQos-4.0-Broadcast-Vid
 match dscp cs5
 match dscp af11
 match dscp af12
 match dscp af13
class-map match-any AutoQos-4.0-Scavenger-Queue
 match dscp cs1
 match cos  1
class-map match-any AutoQos-4.0-VoIP
 match dscp ef
 match cos  5
 match dscp af41
 match dscp af42
 match dscp af43
class-map match-any AutoQos-4.0-Control-Mgmt-Queue
 match cos  3
 match dscp cs7
 match dscp cs6
 match dscp cs3
 match dscp cs2
class-map match-all AutoQos-4.0-Bulk-Data-Classify
class-map match-any AutoQos-4.0-Trans-Data-Queue
 match cos  2
 match dscp af21
 match dscp af22
 match dscp af23
 match dscp af31
 match dscp af32
 match dscp af33
class-map match-any AutoQos-4.0-VoIP-Data
 match dscp ef
 match cos  5
class-map match-all AutoQos-4.0-Internetwork-Ctrl
 match dscp cs6
class-map match-all AutoQos-4.0-Realtime-Interact
 match dscp cs4
class-map match-all AutoQos-4.0-Multimedia-Conf-Classify
class-map match-any AutoQos-4.0-VoIP-Signal
 match dscp cs3
 match cos  3
policy-map AutoQos-4.0-Input-Policy
 class AutoQos-4.0-VoIP
 class AutoQos-4.0-Broadcast-Vid
 class AutoQos-4.0-Realtime-Interact
 class AutoQos-4.0-Network-Ctrl
 class AutoQos-4.0-Internetwork-Ctrl
 class AutoQos-4.0-Signaling
 class AutoQos-4.0-Network-Mgmt
 class AutoQos-4.0-Multimedia-Conf
 class AutoQos-4.0-Multimedia-Stream
 class AutoQos-4.0-Transaction-Data
 class AutoQos-4.0-Bulk-Data
 class AutoQos-4.0-Scavenger
policy-map AutoQos-4.0-Output-Policy
 class AutoQos-4.0-Scavenger-Queue
  bandwidth remaining percent 1
 class AutoQos-4.0-Priority-Queue
  priority
 !!  police cir percent 30 bc 33 ms !! removed because I don't want to police internally
 class AutoQos-4.0-Control-Mgmt-Queue
  bandwidth remaining percent 10
 class AutoQos-4.0-Multimedia-Conf-Queue
 class AutoQos-4.0-Multimedia-Stream-Queue
 class AutoQos-4.0-Trans-Data-Queue
  !!!  dbl removed because it's not supported !!!
 class AutoQos-4.0-Bulk-Data-Queue
  bandwidth remaining percent 4
 class class-default
  bandwidth remaining percent 25
ip access-list extended AutoQos-4.0-ACL-Bulk-Data
 permit tcp any any eq ftp
 permit tcp any any eq ftp-data
 permit tcp any any eq 22
 permit tcp any any eq smtp
 permit tcp any any eq 465
 permit tcp any any eq 143
 permit tcp any any eq 993
 permit tcp any any eq pop3
 permit tcp any any eq 995
 permit tcp any any eq 1914
ip access-list extended AutoQos-4.0-ACL-Default
 permit ip any any
ip access-list extended AutoQos-4.0-ACL-Multimedia-Conf
 permit udp any any range 16384 32767
ip access-list extended AutoQos-4.0-ACL-Scavenger
 permit tcp any any eq 1214
 permit udp any any eq 1214
 permit tcp any any range 2300 2400
 permit udp any any range 2300 2400
 permit tcp any any eq 3689
 permit udp any any eq 3689
 permit tcp any any range 6881 6999
 permit tcp any any eq 11999
 permit tcp any any range 28800 29100
ip access-list extended AutoQos-4.0-ACL-Signaling
 permit tcp any any range 2000 2002
 permit tcp any any range 5060 5061
 permit udp any any range 5060 5061
ip access-list extended AutoQos-4.0-ACL-Transactional-Data
 permit tcp any any eq 443
 permit tcp any any eq 1521
 permit udp any any eq 1521
 permit tcp any any eq 1526
 permit udp any any eq 1526
 permit tcp any any eq 1575
 permit udp any any eq 1575
 permit tcp any any eq 1630
 permit udp any any eq 1630
<interface commands>
 auto qos video cts
 qos trust device cts
Preston Kilburn
I eventually abandoned this approach and then used the built in setting of LiveAction on these particular links.  Turns out the 6500's with these line cards only do inbound queue and marking.  Kind of kludgey so we're doing some minimum configs until the gear can get cycled out to newer stuff.
