Policy Based Routing with Tracking
Hi Guys,
I'm trying to implement policy based routing with ip sla tracking but can't find the  verify-availability option in our C4510R+E with SUP7-E. Is it available in 4510R switches?
Thanks in Advance,
Chandimal
sumit menaria
Can you try to use PBR Match track object,
Device(config)# route-map abc
Device(config-route-map)# match track 2
Device(config-route-map)# end
Device# show route-map abc
route-map abc, permit, sequence 10
  Match clauses:
    track-object 2
  Set clauses:
  Policy routing matches: 0 packets, 0 bytes
Additional References for PBR Match Track Object
This feature is a part of IOS-XE release 3.13 and later.
Cisco IOS XE Release 3.13S
The PBR Match Track Object feature enables a device to track the stub object during Policy Based Routing.
The following commands were introduced or modified: match track tracked-obj-number
Cheers,
Sumit
Hi Sumitmenaria,
I can't see that option under PBR on our switches running Version 03.04.03.SG and the switch switches are 4510R+E. I've checked the latest IOS for 4510R+E but could find a version 3.13S.
