Auto QoS for Switch
nshoe18
I have a series of 2960-24LC-S switches running IOS 12.2(50) SE4. I cannot get Auto QoS to run on the ports as is done with a 3560 for example. Anyone have any ideas?
jonathanaxford
Level 3
Level 3
Are these switches running the "LAN-Lite" software? If so, the QoS capabilities are more limited than you find on the LAN-base image or on the 3560 series of switches - the two configs will not be the same.
The following config guide has more info on the QoS settings for the 2960 lite:
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_37_ey/configuration/guide/swqos.html
Hope this helps a little,
Jonathan
