auto qos on uplinks?
billmatthews
We have a stack of 2960s at our access layer, connecting up (via a pair of fibers in a port channel) to our 3750x at the core.
We will have Cisco VoIP phones connecting to the access layer.  So for each switchport I've used auto qos voip cisco-phone.  But for the uplink ports do I need any QoS?  I would imagine I do at least need trust, but I can't seem to use auto qos on the uplink ports (says it's not valid on a trunk).
Do I need to configure any QoS, either on the physical uplink interfaces or on the Port Channel?
Bill
5 Replies 5
If you enforce QoS on the access-Layer, then you should just trust the DSCP-settings coming in on your Uplinks and activate the priority-queues on the ports. That can also be done with auto-qos:
switch(config-if)#   auto qos trust dscp
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
The problem is there are members of a port channel...
(config-if)#auto qos trust dscp
AutoQoS Error: AutoQoS can not be configured on member port(s) of a port-channel
ok, if the switch doesn't like auto qos, then i would use the "native" commands:
interface range Gig1/0/1 -2
  mls qos trust dscp
  queue-set 2
  priority-queue out
(That assumes that auto qos is used on other ports so that the queue-set 2 and other things are already set)
@Amrinder: The capability to trust COS or DSCP has nothing to do with the settings of the interface as L2- or L3-Port. It's just a decision which information is more trustworthy in a given situation.
Hello Karsten,
I have a similar issue. Interfaces 1-48 are user facing with the following configuration.
description USER_PORTS
switchport access vlan 10
switchport mode access
switchport voice vlan 20
logging event link-status
srr-queue bandwidth share 1 30 35 5
priority-queue out
mls qos trust device cisco-phone
mls qos trust cos
spanning-tree portfast
spanning-tree bpduguard enable
service-policy input AUTOQOS-SRND4-CISCOPHONE-POLICY
and I am not sure how to configure my uplink ports that are in a channel group.
switchport trunk native vlan 998
switchport trunk allowed vlan 5,10,20
switchport mode trunk
logging event trunk-status
channel-group 45 mode active
CW-SW-PP1-3750#sh mls qos queue-set
Queueset: 1
Queue : 1 2 3 4
buffers : 15 25 40 20
threshold1: 100 125 100 60
threshold2: 100 125 100 150
reserved : 50 100 100 50
maximum : 200 400 400 200
Queueset: 2
Queue : 1 2 3 4
buffers : 25 25 25 25
threshold1: 100 200 100 100
threshold2: 100 200 100 100
reserved : 50 50 50 50
maximum : 400 400 400 400
Do I just need to send the
mls qos trust dscp
  queue-set 2
  priority-queue out
commands to the uplink ports?
singhaam007
Level 3
Level 3
Hi Bill,
You can use Auto Qos trust cos if the interface is layer 2 but use Auto Qos trust DSCP for layer 3 interface.
Try Auto qos trust on your uplink
thanks
