ā04-01-2013 05:21 AM - edited ā03-07-2019 12:33 PM
We are facing cold start issue on 4500 series switch. The switch is restarting automatically almost weekly twice or thrice.
As per show tech. output , there is "cold start log".Please find the attached logs for your reference.
Please help urgently to resolve issue & which may cause the issue?
After time change , auto restart happening & am not found any log for power failure also.
Shanmugam
ā04-01-2013 10:26 AM
Since the 4500 series are Catalyst switches, they are supported by TAC not SBSC. You may move this topic to the proper forum but for an issue like that, I would just call TAC and open an incident.
ā04-01-2013 10:29 AM
This post has been moved to the correct area.
Cindy Toy
Cisco Small Business Community Manager
for Cisco Small Business Products
www.cisco.com/go/smallbizsupport
twitter: CiscoSBsupport
ā04-01-2013 09:47 PM
Pls help ASAP.
Awaiting for reply..
NSP
ā04-01-2013 09:56 PM
Post the following output:
1. dir
2. sh version
ā04-01-2013 10:08 PM
please refer the below log.
------------------ show version ------------------
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-IPBASEK9-M), Version 12.2(53)SG, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Thu 16-Jul-09 21:52 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x1258A1FC
ROM: 12.2(44r)SG5
Darkside Revision 4, Jawa Revision 9, Tatooine Revision 140, Forerunner Revision 1.21
BOB_3RDFLR_SW_1 uptime is 3 minutes
System returned to ROM by reload
System image file is "bootflash:cat4500e-ipbasek9-mz.122-53.SG.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
cisco WS-C4506-E (MPC8548) processor (revision 8) with 524288K bytes of memory.
Processor board ID FOX1405G661
MPC8548 CPU at 1GHz, Supervisor 6L-E
Last reset from Reload
5 Virtual Ethernet interfaces
96 FastEthernet interfaces
100 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
------------------ dir nvram: ------------------
Directory of nvram:/
512 -rw- 9123
513 ---- 5
514 -rw- 9123
1 ---- 174
2 ---- 0
3 -rw- 0
524284 bytes total (512032 bytes free)
ā04-01-2013 11:47 PM
Hi Shanmugam,
I have reviewed the outputs and the decodes in the crashdump show that this
crash was due to a parity error.
Possible causes of these parity errors are random static discharge or other
external factors.
We have two types of these errors:
Soft parity errors
These errors occur when an energy level within the chip (for example, a one
or a zero) changes, most often due to radiation. When referenced by the CPU,
such errors cause the system to crash. In case of a soft parity error, there
is no need to swap the board or any of the components.
Hard parity errors
These errors occur when there is a chip or board failure that corrupts data.
In this case, you need to re-seat or replace the affected component, which
usually involves a memory chip swap or a board swap.
Moving forward with this case we need to monitor the device 2 days and if
the device is stable, this can be considered a soft parity (one-time
incident). If the device crashes again then this would be a HW failure and
we need to proceed with RMA.
Inayath
*Plz rate this info is helpfull.
