auto reboot
bsurace
Community Member
hi all,
is it possibe to reboot a router cisco 830 when the outside connexion is lost ? and how ? maybe with Kiwi Syslog Daemon ?
thx.
glen.grant
If you can't get to the router then there is no way to reboot other than power off the unit at the site.
xcz504d1114
Level 7
Level 7
Rebooting is also a troubleshooting nightmare, you can loose a lot of data regarding the problem you are experiencing by rebooting.
CSCO10106129
Community Member
though this may not help you now, it may in the future.
you can schedule a reload of the ios.
if you are doing some tricky configuration and you lose connectivity, the scheduled reload will take place and bring up the old startup-config
command: reload in 10
outcome: will reload router in 10 minutes
don't forget to "reload cancel" command if your changes are as planned and do not want to reload router.
