Showing results forĀ
Search instead forĀ
Did you mean:Ā
Auto-redundancy using etherchannel in 2960 not working.
sarmedRahman
I'm using Packet Tracer for testing since I don't have the actual equipment. I have configured etherchannel between two 2960 Switches. I have used the trunk ports FE  0/23 and FE 0/24 on both switches to create the etherchanel. I have connected one PC with each switch. The PCs are in the same VLAN and can ping each other. Howver, when I take down one of the links in the etherchannel, the other link does not take over and I get 100% packet loss. I don't know what seems to be the problem. I'm quoting the configurations below:
Switch0:
Switch#sh running-config
Building configuration...
Current configuration : 1179 bytes
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Switch
spanning-tree mode pvst
! OUTPUT TRUNCATED !
interface FastEthernet0/23
channel-group 5 mode on
switchport mode trunk
interface FastEthernet0/24
interface GigabitEthernet1/1
interface GigabitEthernet1/2
interface Port-channel 5
interface Vlan1
no ip address
shutdown
end
Switch#show interfaces trunk
Port        Mode         Encapsulation  Status        Native vlan
Fa0/23      on           802.1q         trunking      1
Fa0/24      on           802.1q         trunking      1
Po5         on           802.1q         trunking      1
Port        Vlans allowed on trunk
Fa0/23      1-1005
Fa0/24      1-1005
Po5         1-1005
Port        Vlans allowed and active in management domain
Fa0/23      1
Fa0/24      1
Po5         1
Port        Vlans in spanning tree forwarding state and not pruned
Fa0/23      1
Fa0/24      1
Po5         1
Switch#show etherchannel summary
Number of channel-groups in use: 1
Number of aggregators:           1
Group  Port-channel  Protocol    Ports
5      Po5(SU)           -      Fa0/23(P) Fa0/24(P)
Switch 1:
version 12.2
hostname Switch
interface Vlan1
no ip address
shutdown
end
Fa0/23      1-1005
Fa0/24      1-1005
Po5         1-1005
Fa0/23      1
Fa0/24      1
Po5         1
Fa0/23      1
Fa0/24      1
Po5         1
sarmedRahman
I don't know why isn't it working..
glen.grant
  If the channel shows up with only 1 port being int he channel when you shut 1 port down   then it's probably a packet tracer issue.  You can't rely on everything you see in some of these emulator  programs.  I ahve never used PT but if you can check and see where it knows the mac address of the other pc then maybe you can troubleshoot .  Does it still know the mac of the other pc across that etherchannel.
sarmedRahman
It was a packet tracer issue. I have tried etherchannel with actual cisco 2960 switches and it is working. This thread may be closed.
