01-22-2014 09:20 AM - edited 03-07-2019 05:43 PM
Hi Routing and Switching Experts,
Can you please help me to evaluate this Auto RP w/MSDP configuration and tell me what is incorrect or missing.
According to my colleague, I was supposed to add:
access-list 1 permit 239.0.0.0 0.255.255.255
ip pim rp-address 192.168.10.1 1
which I have, but it has not resolved the problem. Any thoughts?
Best Regards,
JRossi
6504-1 ip multicast-routing distributed interface Loopback10 ip address 192.168.10.1 255.255.255.0 ip pim sparse-mode ! interface Loopback20 ip address 192.168.20.1 255.255.255.0 ip pim sparse-mode ip pim rp-address 192.168.10.1 1 ip pim send-rp-announce Loopback20 scope 16 group-list 11 ip msdp peer 192.168.30.1 connect-source Loopback20 access-list 1 permit 239.0.0.0 0.255.255.255 access-list 10 permit 239.11.11.11 access-list 11 permit 239.0.0.0 0.255.255.255 ip msdp originator-id loopback20 router ospf 100 network 192.168.20.0 0.0.0.255 area 0 network 192.168.30.0 0.0.0.255 area 0 | 6504-2 ip multicast-routing distributed interface Loopback10 ip address 192.168.10.1 255.255.255.0 ip pim sparse-mode ! interface Loopback30 ip address 192.168.30.1 255.255.255.0 ip pim sparse-mode ip pim rp-address 192.168.10.1 1 ip pim send-rp-announce Loopback30 scope 16 group-list 11 ip msdp peer 192.168.20.1 connect-source Loopback30 access-list 1 permit 239.0.0.0 0.255.255.255 access-list 10 permit 239.11.11.11 access-list 11 permit 239.0.0.0 0.255.255.255 ip msdp originator-id loopback30 router ospf 100 network 192.168.20.0 0.0.0.255 area 0 network 192.168.30.0 0.0.0.255 area 0
01-22-2014 10:26 AM
ip pim send-rp-discovery seems to be missing I think. You need this mapping agent. Ensure you have the listener command set on others, though i think new ios does this already?
You do not really need the access-list and the static RP entry in my view, unless you have specific requirement..
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
01-22-2014 10:36 AM
Hello, John.
If you had only these two routers it would work.
But to make auto-rp to work with some environment you should add:
Are you trying to implement anycast RP? In this case you should make Lo10 to become RP.
Anycast RP example could be found here:
http://www.cisco.com/en/US/docs/ios/solutions_docs/ip_multicast/White_papers/rps.html
but they use sparse-dense mode, so missing autorp listener
PS: why don't you use BSR?
01-22-2014 10:40 AM
Hi John,
The "send-rp-announce" and "send-rp-discovery" should be using the anycast address (lo10) as described in the following document:
01-22-2014 02:02 PM
Hi All,
It looks like I had an Auto-RP line configured that was unneccisary. After removing the rp-announce command and adding the network 192.168.10.0 into area 0, the MSDP peers came up, but the "show ip pim rp" still resulted in a no output.
6504-1#sh ip pim rp
6504-1#
It wasn't until I added the following commands to the VLAN SVI that I could even ping 239.11.11.11.
Is that normal behavior? Why?
For Example:
6504-1(config)#int vl 129
6504-1(config-if)#ip pim sparse-mode
6504-1(config-if)#do sh ip pim rp
6504-1(config-if)#ip igmp join-group 239.11.11.11
6504-1#sh ip pim rp
Group: 239.255.255.250, RP: 192.168.10.1, next RP-reachable in 00:01:18
Group: 239.9.9.9, RP: 192.168.10.1, next RP-reachable in 00:01:20
Group: 239.11.11.11, RP: 192.168.10.1, next RP-reachable in 00:01:21
I changed the configuration as follows:
6504-1 ip multicast-routing distributed interface Loopback10 ip address 192.168.10.1 255.255.255.0 ip pim sparse-mode ! interface Loopback20 ip address 192.168.20.1 255.255.255.0 ip pim sparse-mode ip pim rp-address 192.168.10.1 11 ip msdp peer 192.168.30.1 connect-source Loopback20 access-list 10 permit 239.11.11.11 access-list 11 permit 239.0.0.0 0.255.255.255 ip msdp originator-id loopback20 router ospf 1 network 192.168.10.0 0.0.0.255 area 0 network 192.168.20.0 0.0.0.255 area 0 network 192.168.30.0 0.0.0.255 area 0 | 6504-2 ip multicast-routing distributed interface Loopback10 ip address 192.168.10.1 255.255.255.0 ip pim sparse-mode ! interface Loopback30 ip address 192.168.30.1 255.255.255.0 ip pim sparse-mode ip pim rp-address 192.168.10.1 11 ip msdp peer 192.168.20.1 connect-source Loopback30 no access-list 10 permit 239.11.11.11 access-list 11 permit 239.0.0.0 0.255.255.255 ip msdp originator-id loopback30 router ospf 1 network 192.168.10.0 0.0.0.255 area 0 network 192.168.20.0 0.0.0.255 area 0 network 192.168.30.0 0.0.0.255 area 0
I removed ACL 10 because it only pointed to 239.11.11.11. According to our "X" multicast expert, we needed the entire subnet to be allowed, just in case we need to create and use additional multicast groups. Also, there were no rp-address statements referencing ACL 10.
Does this make sense to the multicast experts online?
Any additional advice or assitances would be appreciated.
Best Regards,
JRossi
01-22-2014 05:07 PM
Hi John,
Your updated configuration is plain Anycast RP. Which is fine, but you will need to configure a static RP on all other routers needing to deliver multicast in your network. The initial configuration was a combination of Anycast RP and auto-rp, where you wouldn't need to configure a static RP on all routers as it would be discovered via auto-rp.
01-23-2014 08:26 AM
Hi Harold,
I am reading the white paper you sent me.
How could I modify the configuration to use Auto RP with MSDP peers?
Before our multicast guy left the company, I believe it was his plan to use Auto RP. I just need to make sure that there is a statement which allows the entire 239.0.0.0 /8 subnet, which I believe in the ACL is 239.0.0.0 0.0.0.255.
Best Regards,
John
01-23-2014 09:16 AM
Hi John,
Well, you do not need MSDP peers if you run Auto RP by itself. You will need msdp peers in the context of Anycast RP. The following section of the white paper covers Anycast RP with Auto RP to distribute the Anycast RP address.
http://www.cisco.com/en/US/docs/ios/solutions_docs/ip_multicast/White_papers/rps.html#wp1036139
How many routers do you have in your network? Depending on the number of routers, it might be just fine to go and configure the static RP on all routers that need to support multicast. If the number of routers needing to support multicast is high, it might be easier to use Auto RP to distribute the Anycast RP address.
01-23-2014 10:56 AM
Hi Harold,
This is a Multicast POC @ a single location with 2 core 6509's.
This is mostly for our wireless network, which has 2 different multicast groups.
The first is for the Multicast Redirect feature which uses 239.9.9.9.
Our controllers use 239.2.2.2 and 239.11.11.11 is utilized for a medical application that uses video. In the end, we will have 15 locations with dual 6k switches. I will play with the configuration to see how Auto RP works, but Anycast RP might be fine. I was told that our primary requirement was to ensure that Multicast was implmented w/ fault tolerence. I assume the use of the static RP configured on both sides facilitates that?
Do you see any problem with the existing configuration?
Best Regards,
John
01-24-2014 06:35 AM
Hi John,
If your multicast network consists of only these two 6500, I do not see any advantage in deploying Auto-RP. You could just use Anycast RP with static RP. This would be much simpler.
01-23-2014 05:23 PM
Hi Harold,
I set something up in GNS3 to simulate an Auto RP configuration.
R1 - Setting to announce as RP
ip pim send-rp-announce f1/0 scope 16 group-list 11
R1#sh ip pim rp mapping
PIM Group-to-RP Mappings
This system is an RP (Auto-RP)
Group(s) 239.0.0.0/8
RP 192.168.10.1 (?), v2v1
Info source: 192.168.10.3 (?), elected via Auto-RP
Uptime: 00:33:18, expires: 00:02:21
R2 - Setting to Mapping Agent
ip pim send-rp-discovery int f1/0 scope 16
ip pim autorp listener
R2#sh ip pim rp mapp
This system is an RP-mapping agent (FastEthernet1/0)
Info source: 192.168.10.1 (?), elected via Auto-RP
Uptime: 00:34:42, expires: 00:02:18
R3
R3#sh run int f1/0
interface FastEthernet1/0
ip address 192.168.12.1 255.255.255.0
ip pim sparse-mode
ip ospf 1 area 0
duplex auto
speed auto
So, a couple of questions.
1. Why when I ping the Mcast Grp address, do I only get responses from the 11 and 12 subnet? Shouldn't the RP at 10.1 also respond or do I only get responses from the mapping agent?
2. When I take down R1, which has the RP announce command configured, why doesn't the multicast group go down?
I thought that when the OSPF dead timer expired, the multicast group would become unavailable?
R3#ping 239.11.11.11 re 500
Sending 500, 100-byte ICMP Echos to 239.11.11.11, timeout is 2 seconds:
Reply to request 0 from 192.168.12.1, 16 ms
Reply to request 0 from 192.168.12.1, 272 ms
Reply to request 1 from 192.168.12.1, 24 ms
Reply to request 1 from 192.168.12.1, 36 ms
Reply to request 1 from 192.168.12.1, 32 ms
!! R1 !!
Reply to request 1 from 192.168.11.2, 32 ms
Reply to request 2 from 192.168.12.1, 24 ms
Reply to request 2 from 192.168.12.1, 36 ms
Reply to request 2 from 192.168.12.1, 32 ms
Best Regards,
John
01-24-2014 06:46 AM
Hi John,
1- Unless you have other receivers for group 239.11.11.11, only the interfaces configured with "ip igmp join-group 239.11.11.11" will respond to the ping. The RP and mapping agent do not respond to ping to this multicast group unless they are configured wit that samre command.
2- The entry for the multicast group will remain for a certain time even if it is not being used.
