auto summary command issue
datamodule
Level 3
Level 3
I am having 2911 router running with C2900 Software (C2900-UNIVERSALK9-M), Version 15.1(4)M5, RELEASE SOFTWARE (fc1)IOS and i have configured the following commands for eigrp
router eigrp 100
network 10.20.0.0
no auto-summary
It takes all 3 commands but when i check through show run command i am not seeing no auto-summary command.
Can you please let me know is something wrong with my config
Correct, but this has been default before IOS 15.0 .  According to the command reference guide it is default starting with ver 10
http://www.cisco.com/en/US/docs/ios/12_2/iproute/command/reference/1rfeigrp.html#wp1017389
5 Replies 5
Reza Sharifi
That is because no auto-summary command is on by default.
auto-summary (EIGRP)
To restore the default behavior of automatic summarization of subnet routes into network-level routes, use the auto-summary command in router configuration mode. To disable this function and send subprefix routing information across classful network boundaries, use the no form of this command.
auto-summary
no auto-summary
Syntax Description
This command has no arguments or keywords.
Defaults
The behavior of this command is enabled by default (the software  summarizes subprefixes to the classful network boundary when crossing  classful network boundaries).
datamodule
Level 3
Level 3
thanks for that Please correct me if i am wrong
By default auto-summary will be enabled that is why we don't see but if i run no auto-summary command that should show.
This is new in
Thank you
Correction
The "auto summary" command started in ios 10, but the no auto summary started in 12.2(8)T.
here is the command reference guide for more info;
http://www.cisco.com/en/US/docs/ios-xml/ios/iproute_eigrp/command/ire-a1.html#GUID-DD4D7C28-4F31-4AC5-ABF7-697194696B10
