AUTO-TUNNEL CREATION
pranavsidam
Community Member
I just configured  my  router for connection with exchange using ospf routing protocol to receive multicast traffic.
but when i issue the command "show ip int brief " on my router it shows tunnel interface.The interface is automatically created and the source ip is the ip assigned to wan interface of my router.
is this because i configured ip pim sparse mode on my wan interface.
indeed this is normal behavior when you configure PIM sparse mode. The tunnel is created automatically by the Multicast Forwarding Information Base (MFIB) as part of the PIM sparse-mode registration process.
Georg Pauwen
post the configuration of your router. What do you mean with 'exchange' ?
exchange means trading exchange from where i want multicast.
router config:
interface GigabitEthernet0/0
 description ***** MEMBER LAN *****
 ip address 10.y.y.y 255.255.255.192
 ip access-group 168 in
 no ip redirects
 no ip proxy-arp
 ip pim sparse-mode
 duplex full
 speed 1000
interface GigabitEthernet0/1
 description ***** NCDEX WAN *****
 bandwidth 2048
 ip address 10.x.x.x.x 255.255.255.252
 no ip redirects
 no ip proxy-arp
 ip pim sparse-mode
 ip igmp join-group 239.x.x.x
 duplex full
 speed 100
router ospf 2
 router-id 10.y.y.y
 network 10.x.0.0 0.0.255.255 area 2
 network 10.y.0.0 0.0.255.255 area 2
ip pim rp-address 10.z.z.z NCDEX_MUL override
ip pim rp-address 10.z.z.z NCDEX_DR_MUL override
access-list 168 permit igmp 10.y.y.y 0.0.0.63 host 239.x.x.x
router#sh ip int br
Interface                  IP-Address      OK? Method Status                Protocol
Embedded-Service-Engine0/0 unassigned      YES NVRAM  administratively down down
GigabitEthernet0/0         10.y.y.y   YES NVRAM  up                    up
GigabitEthernet0/1         10.x.x.x   YES NVRAM  up                    up
Tunnel0                    10.x.x.x   YES unset  up                    up
